Unusual HiFi products from the past.
1…101112131416»
    mhardy6647 Posts: 35,562
    oh, yeah, baby! -- field coils are where it's at! B)
    I know some guys...
    https://hifiheroin.blogspot.com/search?q=tungar
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,394
    I suppose you could think of electrostatic speakers as "field coil" speakers when compared with "magnetic planar" type speakers.
    edited May 2022
    Well -- not really... but, I mean, you know that. :)
    (EDIT: But -- yeah -- I do see your point, and take it! :) )
    Electrostatic transducers use a high voltage DC field (thousands of volts) with very little current. Like Dogbert -- I mean, Thor, Dog of Thunder.
    https://dilbert.com/strip/1990-01-10
    Electromagnets (field coils) are energized with fairly low voltage DC (tens of volts) but usually with significant amounts of current.
    In the old days, the loudspeaker field coil often served double-duty as a power supply choke (inductor), too! :)
    There are - arguably ;) - real advantages to using electromagnets instead of permanent magnets... although electrical efficiency isn't one of those advantages. B)
    I will confess that I cannot help but think about scrap metal yards when I think about electromagnets.
  • SeleniumFalcon
    Odd Job likes electromagnets in his line of work.
    ... and ain't that a great, early (Falcon-based) Ford Ranchero?! :)
  • OleBoot
    OleBoot Posts: 3,138
    Not DIS Walkman, but....
    OleBoot wrote: »
    Q:
    What do you call somebody else's panda?
    A:
    B)
    source: https://icouldbeahero.blogspot.com/search?q=panda
  • SeleniumFalcon
  • SeleniumFalcon
  • SeleniumFalcon
    Did they sell a CD rewinder, too -- or were those just for rental DVDs?
    B)
  • Unknown
  • SeleniumFalcon
  • SeleniumFalcon
  • SeleniumFalcon
  • SeleniumFalcon
  • SeleniumFalcon
  • skrol
    skrol Posts: 3,497
    Improves AM performance... I am sure that is what we are all after. Neat find though.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • SeleniumFalcon
  • SeleniumFalcon
  • SeleniumFalcon
  • tramp59
    tramp59 Posts: 13
    Wonder how well that worked?
    Life has become immeasurably better since I have been forced to stop taking it seriously.
    HST
    edited June 2022
    Since I had dug this up for something else, might as well drop it here, too. ;)
    The Esquire is a pretty interesting little loudspeaker -- a lot like the Klipsch Heresy (small-ish sealed box, high sensitivity, good dynamics -- and the same tweeter!) but, unlike the Heresy, a much, much better sounding midrange driver (direct radiator instead of horn/compression driver).
    B)
  • Unknown
    $123.00 shoot I'll take 2
    I mean, I paid less than that for mine... but, heck yeah. ;)
  • soundfreak1
    soundfreak1 Posts: 3,414
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    child's toy.
  • soundfreak1
    I have been 1 upped. LMAO
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • skrol
    skrol Posts: 3,497
    Should take those to he Headphones forum.
    Stan
    Main 2ch:
    HT:
    Other stuff:
