My down-sizing pics.. Anybody else have any you want to share?
1…8910111214»
  • verb
    verb Posts: 10,176
    Looks awesome Tony!
    Tony M Posts: 12,028
    edited April 2022
    Time to get busy clearing out stuff from inside the cottage again. But I have noticed something has to be done on left side porch and the steps I've had temporarily in place for 10 years now.
    This walk-way is 40' long! Sure is an optical illusion in this picture. :o
    My 2nd Heaven;
  • DaveHo
    DaveHo Posts: 3,584
    Lookin good. What are you going to cover the Tyvek with?
    I have been planning to put vinyl siding on it for 20 years or more. I've done quite a few siding jobs in my life, and I know how easy it is to do. Just don't nail the siding tight or it will buckle like he**.
    I was siding a small house and an inspector man shows up to look around. He leans over a deck handrail and asks me, why aren't you nailing the nails all the way down? I told him politely and he says, hum, that makes sense, and he left me to go look at other things. He was kind-of young and new at his job I'm sure.
    I was new at siding in my first job and I didn't even know that one panel overlaps the previous one. Or the laps overlapping the nailed one should be toward the front of the building so you can't see the overlap from the street view. Tricks of the trade knowledge stuff. I read the instructions on the box before my first panel was hung and still didn't understand the overlap scale of about 6". He**, I left the panels butted together. I knew it was wrong but only did the 2 panels and I stopped because it didn't make sense. My boss showed up in a few minutes and shook his head. He said he thought I was smarter than that. :D
    After I could afford to do anything cost wise, I decided to put ceiling boards on the inside of the cottage's rooms first BECAUSE bugs would show up once in a while and I hate roaches and spiders bigtime.
    I bought new homeowner scaffolding to put the ceiling boards up first and I knew I would later use them to put the siding up.
    Not long ago, maybe last year, I bought a 3rd scaffolding to reach the peak in the back of the building. I acquired a safety cage with one scaffold purchase, so I will probably use it on the back side. The back side, if I fall off, I'd hit a chain link fence and at a corner section at that. A corner post point in my back scares me as bad as the razor-like top rail of the fence attached to the top rail. That would skin all my skin and muscles off of my skeleton on one side. :s
    I just looked at the local stock of siding here in H.D. and Lowe's H.I. night before last. I wanted a pastel green color to match my house but it's not available at either store. I then thought "Cream" to match my shutters and doors on the house. No Cream either.
    They have plenty of "white" siding. I could go white very easily but I think I search again. Maybe a real siding installer could do it for me and be able to get either color I wanted too. I'd have one heck of a job moving my lumber hoard off of the side porch, but I could do it in 2 days easily since I organized it last fall.
    Lastly, I looked at the 3'x4' thick panels of vinyl siding "shake-look" siding. It's very expensive but I can afford it. I read where this kind of siding gets $$$$4 on the gable ends. Maybe I could use cut-offs from one end and put them on the other end. Front to back seems plausible. ;)
    Lastly again.... :D
    I'll be in the shade for 3/4 or more of the job whatever I decide to do. :p
    edited April 2022
    I had a friend call me and said he had decided to get rid of his big stereo stuff and just go with a sound-bar and subs. I told him his JBLs were quite expensive still and he still wanted them gone. Instead of throwing them away or donating them, he thought I might like to have them. No cost at all either.
    Scott brought them over Sunday and we talked a good while about what's been happening to us the past year or so.
    Well the 2 pairs of speakers WERE dirty from being in his garage for what looked like a year. The 2 pioneer sx-3800's need repair but the equalizer is still working he says. If you push a pre-programed button, the dials move up or down BY THEMSELVES. :o;) I saw it in action a few years ago while at his house.
    Well, I'm glad I had room to be able to take these in. I do like Cerwin Vega speakers sound most of the time.
    The speakers really cleaned up very nicely. The CV grills were almost so dirty I didn't think they would clean up. But they did.
    Here's what Scott gave me :) ;
    The backs looked great for some odd reasons. There was hardly any filth at all.
    All the sides of both pair kind-of looked like this. :#
    Then, after a bunch of Windex and a bunch of paper towels, they cleaned up GREAT.
    I then put liquid gold on the JBL L100's to moisturize the veneer. I looked on eBay for some JBL grills and JUST missed a PAIR for 130.00. I would've definitely bought them. The multi cubed ones.
    I had fun finding out what worked and what didn't. I don't like the fact that somebody wants 300.00 for a JBL midrange that I need. My one still works and maybe I'll pursue another way to fix it. ;)
    Oh, the CV grills. I think I used Resolve foaming cleaner. Directions said spray, wait 30 seconds and brush off with a rag or brush. I used a clean big sponge. Then I hosed them with the jet stream.;
  • sucks2beme
    sucks2beme Posts: 5,703
    Is the issue on the JBLs the cones/ rings?
    A good speaker repair shop can fix that. Not cheap
    though. Here in Memphis Hallford's is the go to place.
    He does classics and a lot of pro audio speaker repairs.
    edited April 2022
    Thanks for letting me know a place that fixes this kind of damages. ;)
    One midrange cone is broken pretty good. It works though.
    On the same speaker, the woofer has 2 pokes in the surround.
    The other JBL has a good tweeter but no signal gets to it.
    They sounded better and better the longer I played them off and on Tue. afternoon and night. The Cerwin Vegas are sounding better and better also. I played the CVs for my neighbor an hour ago and they sounded pretty good. You can't tell the surrounds are funky or the one tweeter doesn't work.
    My neighbor left and I went back to doing outside stuff. Then I went into the cottage to put some stuff away and turned the CVs on again. UPTOWN FUNK came on the radio. I just had to turn it up. :D
    These CV speakers are made to play this style of music. B)
    edited May 2022
    I got started on the left side porch of the cottage but got derailed by the tiller purchase and usage. But before that, my old friend giving me those speakers and receivers and eq. took up some time listening to those speakers off and on during rest periods.
    I might make a walkway along the porch with a bunch of short decking boards I've been saving for decades. ;) I'm also contemplating trying to grow grass there again.
    The short boards are in the center of this picture.
    I stayed up VERY late the other night removing the old Cerwin Vega woofer surrounds. I just kept moving onto the next steps with each woofer. My wife got up a few times and just gave me the "LOOK" each time. :s I cleaned the old off and glued the new surrounds to the cones. Went to bed at around 3:30am. :o
    They turned out pretty good.
    Oreo was watching me off and on from one of his resting spots. :D
    The old... :s
    The new... :p
    I sure like re-foaming surrounds. ;)
    edited May 2022
    How can Parts Express have this as a "go to" video for re-foaming a surround?! :o:s
    https://youtu.be/jwcfP5pKeek
    One commenter said it is a "Hack Job" and I have to agree.
    I guess Parts Express wants to appease an audience where this kind of workmanship and end result is just fine. :#
    edited February 2023
    Well, My PC told me ( with the pop-up of pics taken on this date over the years thing) it's been 2 years since I regained a lot of space in the cottage. The music is still AWESOME anytime I'm out there. I'm truly blessed!
    I've enjoyed my ability to ACCESS most anything I own with little effort for 85% of what I own. The rest just takes some effort to move stuff out of the way like that TETRIS game a member here described.
    I got really tired after rotating the wife's car tires so I took a long vacation and got the rest I think I needed.
    I got to thinking about rearranging the back room some more and so I went at it the other night. Then another night. Into the 2 am hours both times. Got a lot done too. I enjoy organizing every time. I have music playing on great systems and speakers while I work. A Nakamichi receiver w/DCM TF350s sounds amazing!
    Well, I've been thinking about my chess table legs that need 1 1/2" + risers added ( for chair arms clearance so they can slide under the table) and I thought about hollow brass cup extensions like a fellow here or on the chess collectors site mentioned to explore. I looked quite a few times and then the other night, I thought maybe I had found the leg foot base cup/w/wheels that I needed. 10.00 ea. or 25.00 each for nicer ones. But...
    I then went to bed and before I fell asleep, I thought about some "Polished Brass Caster wheels" I had collected over the years. I had them in a purple Halloween bucket for 10+ years or more.
    I had organized my back room pretty well, knew where the bucket was and went right to it the next day. They would work but they don't lock. I'll figure that out later. I took out the old leg feet and made the Casters fit tight. I like it. I thought maybe the Blue Painters Tape wrapped around the Casters when I want a stationary table. The blue tape can be easily removed afterward. Anyway, here's what I did.
    I hope they work out. Cost ?... Not much I'm sure. Probably free.
    xschop Posts: 5,899
    Oreo was scopin' the new claw towers. :)
  • stangman67
    stangman67 Posts: 2,334
    Very impressive work Tony! Love your cottage!
    I tend to be a bit of a pack rat myself, luckily my wife forced me to go through my stuff every now and then and get rid of stuff I no longer need or use
    Thanks.
    I need to sell a lot more this spring for sure. ;)
    As I was rearranging the back room and listening to the Nakamichi RE10, Pics from the web.
    https://www.ebay.com/itm/354411731805?hash=item528495db5d:g:WI8AAOSwRQNjfz2k&amdata=enc:AQAHAAAAsFUORMCHDf4qzVhpf6AfSrBAe6rmDd9xT0fdcl/O5vz98atBYAQ6A0rOfT0K450xJMxnKTf0meaUm/58ZAqaBXpOiEleV0jGWyFoddhco2QIypShYGNSOxkcqV2ROb3saVHzYU12IWIiE++htCOxiPQmB+UufrKD2k5plzS/w5rRT5+4fiwqCGM3WLgwui1IhgoIA4mK8sp/Xw44zgCKlrDaBWZJ9zjOTFaFiHkNV2p5|tkp:Bk9SR-jwqqbDYQ
    and TF350's, I thought if that was all I had to listen to music with, I could live with that. It sounds that damn great.
