KARMA: iFi AC iPurifier
Clipdat
Clipdat Posts: 13,098
Part two of the iFi karma giveaway.
This is an iFi AC iPurifier. Pretty nifty device that I thought really worked. I plugged it into the power strip that my AVR/TV, etc is on and noticed a subtle but obvious improvement in image quality. Crazy! Maybe you'll have similar results in your HT or 2ch setup.
To enter pick a number 1-100 and I'll use a random # generator to pick the winner on Thursday evening 5/12.
Only requirement for entry is that you have an actual use for it, and will report back with your findings after you try it in your setup. Thanks!!
