Unusual HiFi products from the past.
1…1011131516
    mhardy6647 Posts: 35,562
    I'm curious about this amplifier, I know William Z. Johnson (founder of Audio Research) had a store in Minneapolis and eventually worked for and then bought the Peploe Electronics company. I wonder if Goodell was involved somehow in the early audio scene.
    Indeed. It is unfamilar to me, too. I may ask some of the local gurus about it.
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,384
    Thank you! @mhardy6647
  • SeleniumFalcon
    This one's for you, @mhardy6647
    edited April 2022
    I think if I had an A-2, I could probably live with mono. B)
    So, about that uncaring ;) amplifier. I asked a couple of places, including the fine little hifi fourm, www.hifihaven.org
    A hifihavenite came up with the schematic (I've been busy today, so I didn't even think to look!):
    One of the Northern New England gurus suggests a fairly simple approach:
    I would suspect since they are both octal tubes that they wired the 6L6 to operate as a triode. When the 6B4 is plugged in the resistor from screen to plate (6L6 triode connection) is floating.
    I am not sure how they manage the separate heater/cathode wiring of the indirectly heated 6L6 vs. the filament/cathode of the DHT 6B4? Maybe I am just really slow... :/
  • SeleniumFalcon
    Thanks, that's great information. I thought maybe it used Billy Z's balanced cross-coupled design.
  • SeleniumFalcon
  • skrol
    skrol Posts: 3,493
    JayCee wrote: »
    ^^^ Brutalist HiFi architecture ;)
    Takes me back to "Computer Controlled" Pioneer of the 80's. Gotta love the LED meters, too....
    Topic: Pioneer Champagne Gold series HiFi's early 80's-https://www.avforums.co.za/index.php?topic=77357.0
    I... I wouldn't mind havin' one of those 'Champagne Series' Pioneers... :blush:
    Not for any particular reason... just... 'cause.
    If you decide to put a Champagne system together, I have a CT-6R cassette deck in good working order that would make a nice addition.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • SeleniumFalcon
    Who knew good ole' B-more had a tape recorder manufacturer?
  • engie490
    engie490 Posts: 447
    KEF Xq5s / Velodyne DD12 / Apollon Purifi 1ET6525SA / SST Thoebe II / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
    edited April 2022
    Not a coffee table format, but 6 speakers 6, too -- from Heathkit! :)
    source of inside page scan: https://worldradiohistory.com/Archive-Catalogs/Consumer/Heathkit-1961-Fall-Winter.pdf
    edited April 2022
    oh, and speaking of Heathkit...
    in case any of all y'all thought subwoofers and/or supertweeters were "modern" (e.g., 1970s) ideas...
    mais non, mon frere B)
    source: https://worldradiohistory.com/Archive-Catalogs/Heathkit-Catalogs/Heathkit-Catalog-1959.pdf
    These used pretty good Jensen drivers. The SS-2 used the P8RS extended range 8" woofer and RP-103 compression tweeter and horn. The SS-1B used some 12" Jensen woofer (not sure which -- teh webz sez P15LS) and, IIRC, the redoubtable Jensen RP302 tweeter.
    I can vouch for the little two-ways (SS-2); they were/are quite pleasant & musical loudspeakers; great with tube amps. :)
    (one of my erstwhile pair)
    (borrowed photos from eBAY)
  • SeleniumFalcon
    edited April 2022
    "...the world's finest recorder of its type"
    That's kind of hard to argue with, isn't it? ;)
  • SeleniumFalcon
    Speaking of Graybar -- WRH has a smattering of their catalogs online now.
    Talk about someone for everyone (in terms of electrical/electronic things, that is)! :)
    https://worldradiohistory.com/Graybar-Catalog.htm
  • engie490
    engie490 Posts: 447
    15-16k in 1949 was a HUGE sum of money !! Shoot that was 6 automobiles worth right there
    Oops...I think you added a number after the decimal point. I see $1.5K. Still a crap ton of money back then.
  • engie490
    engie490 Posts: 447
    This is for sale near me...from the ad:
    "Custom Coffee Table:
    Two 12" Audiobahn Special Edition Subwoofers
    1920 Watt Power Acoustik Amplifier w/ a Mosfet power supply
    Tuned to 33Hz: plays low, powerful, bass.
    Blue neon backlight.
    Plexiglass front, solid oak top, MDF sides/back, PVC ports.
    Does not include power supply to run indoors.
    Price: $400 for everything but the power supply.
    Part-out prices:
    Amp w/ bass knob: $150
    Subs: $100 each
    Love this thing, wife says it's time for it to go!"
  • SeleniumFalcon
  • SeleniumFalcon
  • SeleniumFalcon
    edited April 2022
    How's that for a simple crossover?
  • BlueBirdMusic
    BlueBirdMusic Posts: 3,131
    Ken, I admire your appreciation of things that have come before us.
    Harry / Marietta GA
  • SeleniumFalcon
    Thanks, I think it's good to understand, in a small way, where this hobby came from.
  • SeleniumFalcon
    edited April 2022
    Both highs and lows, must be Boz... ak.
    B)
    PS I don't even recognize the Jensens in that 1949 ad! :o
    16 ohms was a good load for transformer-coupled vacuum tube amplifiers -- still is! ;)
    That said, there is another way to design output transformerless tube amps than the lots of power triodes in parallel route (Atma-Sphere, Transcendent Sound, etc.). Philips and Stephens, among others, went the other route. ;)
    source; http://www.hifilit.com/Stephens/Stephens.htm
    coax with 500 ohm VCs. :)
    I have the 16 ohm morph of that coax -- only one, sadly. :/
  • SeleniumFalcon
    Customode?
    ^^^ Home Theatre, baby!
    B)
