RD0 Billet Faceplate Upgrade
124»
    xschop Posts: 5,414
    That is true, but you COULD be introducing an uneven compressabilty around dome perimeter that you need to look out for. Those 4 new areas of plastic that will now reside between adjacent bosses could resonate. Hopefully not since it is only .010" thick. Just an FYI
    xschop Posts: 5,414
    Hey @Toolfan66, don't know who has that crafty polishing tool, but I don't need it and appreciate the offer sending it out.
    I got another personal set of modded RDO plates programmed on CNC with their new radius to try in the XS-TL's...
    If they exibit the off-axis response like the Dayton plates do, then Ill swap the RDOs back in....
    pitdogg2 Posts: 27,334
    Rob stupid question, why can you not polish them while on the lathe?
    xschop Posts: 5,414
    edited July 2023
    My phalanges are invaluable. I now have a diamond tip insert that is producing the rainbow sheen there. So this next batch will be as close as you can get to a Scotchbrite finish.😉
    Toolfan66 Posts: 18,189
    The tool was sent back to me, I have new scotch pads with it ready go when you’re done making these beautiful faceplates to whoever wants to use it..
    msg Posts: 10,473
    I thought I read in passing on one post that it takes a while? I could be making that up. In fact, it's likely.
    F1nut Posts: 52,009
    What takes a while?
    xschop Posts: 5,414
    What takes a while?
    Trying to find a vintage set of Polks that don't look like they've been used for target practice.
    msg Posts: 10,473
    edited July 2023
    What takes a while?
    Nevermind; I misremembered when Rob said it was his fingers that were the reason for post-polishing. That was in response to Ivan's question, but my post was hit with the Vanilla Time Drift.
    Same thing that happened to the USS Nimitz. They made a documentary about it.
    xschop Posts: 5,414
    msg wrote: »
    'Fraid of a little elbow grease? There's always black paint too...
