Turntable outer ring clamp interest list...
Ok. So the process is similar to metal annealing.
Don't take experimental gene therapies from known eugenicists. -
Checking these out from Wayne's Audio... so far really enjoying the set. Each adds about 2lbs, and it flattens my worst edge warp. Holding off on sharing other observations for a bit pending some additional closer listening.
I'd just mounted a Denon DL-301 cart, new to me, that I had sitting around for a few years after watching Ebay for one for a while, recommended by @jdjohn . The record is one recommended by @SeleniumFalcon, a 1971 Deutsche Grammophon Bedřich Smetana - Boston Symphony Orchestra, Rafael Kubelik - Mein Vaterland (Box + 2xLP)
I disabled signatures. -
Appears that Wayne's Audio has a new outer ring:
On Sale!! Wayne's Audio SS-U Turntable Periphery Stabilizing Outer Ring For any 12" platter
https://www.usaudiomart.com/details/649838777-on-sale-waynes-audio-ss-u-turntable-periphery-stabilizing-outer-ring-clearaudio-vpi-rega-linn-reg/
On his website, there is a Turntable Outer Ring DS-2 Round Sitting Disc Optional for SS-U ring use only:
https://www.waynesaudio.com/product-page/wayne-s-audio-turntable-outer-ring-ds-2-round-sitting-disc-optional-for-ss-u-rin"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Nice! I'm waiting on Wayne to make a sitting disk for the SS-T, which is the ring used for Technics tables. All the rings come with a placement tool that works pretty well, but the disc is more exact.
Plus, you can use the sitting disc to store your ring on your table when not in use. Without the sitting disc, you either need to leave a junk record on the platter, or store the disc in its box.
I really like the WS-2 clamp is nice, too. I haven't had much time for vinyl lately, though.
Wayne seems to be pretty good about offering combo deals as well.I disabled signatures. -
Sent an email to Wayne to ask if this new ring will work on my PL-570. The platter has a diameter of about 12.75 inches or 324mm."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
I have a Wayne’s clamp I use with my Planar 6. Really incredible results reducing rumble and surface noise. I am still not happy with the rega but it will hold me over longer now2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
Curious, what do you dislike about the P6?I plan for the future. - F1Nut
