Turntable outer ring clamp interest list...
    xschop Posts: 5,886
    Ok. So the process is similar to metal annealing.
    msg Posts: 10,650
    edited December 2021
    Checking these out from Wayne's Audio... so far really enjoying the set. Each adds about 2lbs, and it flattens my worst edge warp. Holding off on sharing other observations for a bit pending some additional closer listening.
    I'd just mounted a Denon DL-301 cart, new to me, that I had sitting around for a few years after watching Ebay for one for a while, recommended by @jdjohn . The record is one recommended by @SeleniumFalcon, a 1971 Deutsche Grammophon Bedřich Smetana - Boston Symphony Orchestra, Rafael Kubelik - Mein Vaterland (Box + 2xLP)
  • BlueBirdMusic
    BlueBirdMusic Posts: 3,137
    Appears that Wayne's Audio has a new outer ring:
    On Sale!! Wayne's Audio SS-U Turntable Periphery Stabilizing Outer Ring For any 12" platter
    https://www.usaudiomart.com/details/649838777-on-sale-waynes-audio-ss-u-turntable-periphery-stabilizing-outer-ring-clearaudio-vpi-rega-linn-reg/
    On his website, there is a Turntable Outer Ring DS-2 Round Sitting Disc Optional for SS-U ring use only:
    https://www.waynesaudio.com/product-page/wayne-s-audio-turntable-outer-ring-ds-2-round-sitting-disc-optional-for-ss-u-rin
    Harry / Marietta GA
    msg Posts: 10,650
    Nice! I'm waiting on Wayne to make a sitting disk for the SS-T, which is the ring used for Technics tables. All the rings come with a placement tool that works pretty well, but the disc is more exact.
    Plus, you can use the sitting disc to store your ring on your table when not in use. Without the sitting disc, you either need to leave a junk record on the platter, or store the disc in its box.
    I really like the WS-2 clamp is nice, too. I haven't had much time for vinyl lately, though.
    Wayne seems to be pretty good about offering combo deals as well.
  • BlueBirdMusic
    Sent an email to Wayne to ask if this new ring will work on my PL-570. The platter has a diameter of about 12.75 inches or 324mm.
    Harry / Marietta GA
  • stangman67
    stangman67 Posts: 2,334
    I have a Wayne’s clamp I use with my Planar 6. Really incredible results reducing rumble and surface noise. I am still not happy with the rega but it will hold me over longer now
  • TroyD
    TroyD Posts: 13,124
    Curious, what do you dislike about the P6?
