Early B -
Early's Speaker on a stand...
I need to borrow a level, because my stand is the opposite of level...out of level... ouch- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Oh yeah, I havnt added the foam padding - incase, Early or anyone is wondering, that will be the last thing I do, although I know it will be harder - it is just easier than cutting holes with it in there...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Fantastic! Looks great. Can't wait.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Originally posted by audiobliss
Lookin' real good there, Sid. You keep up the work and you just might be building cabinets for Polk some day.....:p
perhaps Sid could be our SDA MAN!!!!!***WAREMTAE*** -
got plans??
Originally posted by Vr3MxStyler2k3
got plans??
no but if graveling is required I'll buy a set of knee pads;)***WAREMTAE*** -
That sounds highly - highly disturbing.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Foam Pads in place, lower part of cabinet...
Larger majority of the cabinet is covered, there is a huge difference in the amount of reverb with the foam pads in, and with them out - very nice move here, should cancel any back wave present...
Also, I started the other cabinet today...
I should have built a complete enclosure the first time, because I really learned a few things from piecing this past one together that sped up the process alot faster and allowed me to build it alot better...
Shall be interesting... will post pics when time comes... shouldnt be more than 1 week (2 weeks tops)- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Here's a pic of the Fostex full range driver that will fit into Sid's sonic sensations (Hmmm... sounds like a nice name for your company, Sid):HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Holy ****...
Hows the back of that mounting part look man?
I cut the hole 1/16th of an inch to small, and it might be a good thing...
I hate mounting frames like that, ugh!
Thanks for the pics man! Cant wait to hear your thoughts on the sound!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Here's a side view...HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Here's the driver with phase plug installed...HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
And here are the internal wires ready to go -- Tara Labs Prism bi-wire. Yeah, I know, overkill, but I had a few extra feet of it...HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I'd put some type of tape around those ends....(wire)
Thanks for the pics, I'm gonna get em up on the site...
Thats a cool name, maybe a toss up, it or AmpraSid Designs
Yeah, you're right. I'll tape up the ends. Thanks.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Dun dun dun- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
DUN DUN DUN DUN- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
DUN DUN DUN DUN DUN DUN!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
DUN DUN DUN DUN DUN DUN DUN!!!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Which SVS do you have Sid? That thing is massive!
BTW, I tried to just PM you but your box is full...Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
I really hate my PM box....
I delete EVERYTHING, and it still says I have like 60 messages? WTH... anyways, its 'clear'ed - I guess
And I have the PCi 22-31 (25-31 w/ free 22hz tune)- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Are you kidding me? If I didn't know better, I would've thought "Sid's Sonic Sensations" was an adult toy manufacturer;) .
Can't wait to read your review after you've had time to play with them.
Sid,
Great work. I'm very impressed. Looks very professional. You should design an emblem for your speakers now.
Maurice -
Err...Hell..
I'm just glad these turned out the way they did...
I went into this project SCARED...
*NEVER**** worked with angles before...much less a speaker that had to look good on the outside and wasnt being covered with cloth...
I think it turned out good, I just hope Brad (Early
remembers I am a student and just learning
- as there are imperfections on the cabinets, its just all part of the process...things that happened this time around would not happen again....
But, I like them, they turned out really well, kinda sucks to know their not mine! LOL
Anyways...
Thanks Organ...
An emblem... dun dun dun...
I'll think up something :cool:- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Dont those drivers need a folded horn?
Cabs were built off of Fostex's recomended design...
Internal folded horn is recomend, but Fostex said it can be used with normal vented -
http://www.fostexinternational.com/docs/speaker_comp/pdf/recom_enclose/166e_enclrev.pdf- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Oh, I see. So why didn't you just build their folded horn?
My God, do people actually build things like that?? Better hope a cat never gets stuck in one of those...
Thats a bit beyond my abilities...
LOL
Now my black labs...
I covered the hole up, but a cat could easily fit in there...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
You mean you've never tried it yet...
Great job!
Thanks...
Now that I look at it...
It actually wouldnt be to hard to do...
Just as long as you built it with one side off...
Only way I would attempt to do it...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
