1.2TLs A Winter Project
124»
  • bored184
    bored184 Posts: 331
    bored184 wrote: »
    If I run a common ground amp for the highs and a separate common ground amp for the lows do I need the Dreadnaught?
    What are you trying to gain with this?
    The answer is NO but I'd like to hear what you're trying to gain from this.
    To be honest, absolutely nothing. Just trying to understand when the Dreadnaught is needed and when it is not. I could not find an answer to that specific scenario so I thought I would ask.
    Speakers: TL Monitor 10s, RTA 11TLs, Fortes, Thiel CS 1.2
    Amplifiers: ]Ashly FTX 2001 III, Dynaco ST-70, DIY F6
    Pre: Adcom GFP 750, Aikido Tube Pre
    audioluvr Posts: 5,982
    Dreadnaught allows you to use monoblocks or non-common ground amps. They also help improve the dimensional array circuit. There are lots of good common ground amp choices out there that would make those speakers potential come to life. What's your budget?
    pitdogg2 Posts: 27,203
    Even with a common ground amp I found a benefit in using a dreadnaught.
  • bored184
    bored184 Posts: 331
    You use the dreadnaught along with a common ground amp? Can you give more details please.
