SPDIF coaxial cable
If you are looking for a great sounding spdif cable for not a lot of coin, take a look(listen) to this. I have one and it is just as good as my $300+ Black Cat cable.
https://www.amazon.com/Geistnotes-Apogee-Wyde-Cable-WE-RR/dp/B01N5VXVA1/ref=sr_1_2?crid=16NF6C05FNVGV&keywords=apogee+wyde+eye&qid=1643827747&sprefix=apogee+wy,aps,120&sr=8-2&pldnSite=1
Puritan PSM156
    VR3 Posts: 29,654
    Good cable, tried it a while back...
    Did they raise their prices??
    msg Posts: 10,584
    Which Black Cat are you comparing that against, Marvin?
    Clipdat Posts: 13,101
    The one with the nice purr that occasionally bites you if you pet him too much, but he means well and he's a good boy.
  • marvda1
    marvda1 Posts: 4,967
    Puritan PSM156
    pitdogg2 Posts: 27,663
    They're using Canare RCA ends. Those are very good ends, I've made many a cable with those.
  • displayname
    displayname Posts: 1,238
    I heard this cable at Marvin's awhile back. We were just bounding between a few coax cables. I was pretty impressed with this one, and I was somewhat shocked once Marvin showed me the price.
    Discogs
  • erniejade
    erniejade Posts: 6,321
    I agree for the $; it's a darn good cable.
  • BlueBirdMusic
    Marvin, thanks for posting.
    Ordered one on Tuesday the 8th.
    Harry / Marietta GA
    Looks interesting especially for the price. Gonna have to give this one a whirl. Thanks for the heads up Marv.
  • marvda1
    at the time i bought mine with bnc connectors. can't find that option now.
    Puritan PSM156
  • jbreezy5
    jbreezy5 Posts: 1,141
    That strain relief looks serious.
    msg Posts: 10,584
    marvda1 wrote: »
    Is this the one you're talking about, Marvin?
    https://www.amazon.com/Geistnotes-Apogee-Clock-Cable-WE-BB/dp/B01N6XL1XW/
  • marvda1
    edited February 2022
    no, i got the one in my link just with bnc. i don't know the difference in the word clock one and the 75 ohm coaxial.
    I just asked the question on amazon if the two are the same cable just with different connectors.
    Puritan PSM156
  • marvda1
    just got some answers on amazon. seems they are the same cable, but if you can use bnc it is $5 cheaper than the rca version.
    Puritan PSM156
    msg Posts: 10,584
    I like the idea of BNC. Seems like a great way to refine/shorten/purify the signal path further if BNC is an option with the gear, since you're not handing off to a blocky RCA, sometimes of unknown material quality or termination. When I obsess about these things, that is.
  • marvda1
    somewhere i read that it sounds better to start with a bnc connection even if you use an rca adaptor than to go straight rca.
    Puritan PSM156
    VR3 Posts: 29,654
    Bnc is the only true 75 ohm connector.
  • marvda1
    Let's start hearing some reviews.
    Puritan PSM156
  • marvda1
    edited March 2022
    here's their website, i might give their aes cable a try.
    https://geistnote.com/cable-assemblies/digital/
    Puritan PSM156
