SPDIF coaxial cable
marvda1
If you are looking for a great sounding spdif cable for not a lot of coin, take a look(listen) to this. I have one and it is just as good as my $300+ Black Cat cable.
https://www.amazon.com/Geistnotes-Apogee-Wyde-Cable-WE-RR/dp/B01N5VXVA1/ref=sr_1_2?crid=16NF6C05FNVGV&keywords=apogee+wyde+eye&qid=1643827747&sprefix=apogee+wy,aps,120&sr=8-2&pldnSite=1
Puritan PSM156
Puritan PSM156
Good cable, tried it a while back...
Did they raise their prices??- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Which Black Cat are you comparing that against, Marvin?I disabled signatures.
The one with the nice purr that occasionally bites you if you pet him too much, but he means well and he's a good boy.
@msg the mk1 version of this.
https://blackcatcable.com/collections/digital-cables/products/silverstar-75-spdif-cable-universalAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
They're using Canare RCA ends. Those are very good ends, I've made many a cable with those.
I heard this cable at Marvin's awhile back. We were just bounding between a few coax cables. I was pretty impressed with this one, and I was somewhat shocked once Marvin showed me the price.Analog: Hana ML > VPI Prime Signature 21 > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
Discogs -
I agree for the $; it's a darn good cable.
Marvin, thanks for posting.
Ordered one on Tuesday the 8th."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA -
Looks interesting especially for the price. Gonna have to give this one a whirl. Thanks for the heads up Marv.HT SYSTEM-
lsi 9's -
at the time i bought mine with bnc connectors. can't find that option now.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
That strain relief looks serious.CD Players: Sony CDP-211; Sony DVP-S9000ES; Sony UDP-X800M2 (x2); Cambridge Audio CXC
Cables: Tripp-lite 14ga. PCs, Blue Jeans Cable ICs, Philips PXT1000 ICs; Kimber Kable DV30 coaxial ICs; Canare L-4E6S XLR ICs; Kimber Kable 8PR & 8TC speaker cables. -
Is this the one you're talking about, Marvin?
https://www.amazon.com/Geistnotes-Apogee-Clock-Cable-WE-BB/dp/B01N6XL1XW/I disabled signatures. -
no, i got the one in my link just with bnc. i don't know the difference in the word clock one and the 75 ohm coaxial.
I just asked the question on amazon if the two are the same cable just with different connectors.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
just got some answers on amazon. seems they are the same cable, but if you can use bnc it is $5 cheaper than the rca version.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
I like the idea of BNC. Seems like a great way to refine/shorten/purify the signal path further if BNC is an option with the gear, since you're not handing off to a blocky RCA, sometimes of unknown material quality or termination. When I obsess about these things, that is.I disabled signatures.
somewhere i read that it sounds better to start with a bnc connection even if you use an rca adaptor than to go straight rca.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
Bnc is the only true 75 ohm connector.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Let's start hearing some reviews.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
here's their website, i might give their aes cable a try.
https://geistnote.com/cable-assemblies/digital/Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156
