Post a picture... any picture
Dear lawd, some people's kids....
President of Club Polk -
Yeah need a tub like 4 times that size and more space in the openings
Otherwise cool vision- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
^^ I agree, would be easy to remove.2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
The best way to predict the future is to invent it.
It is imperative that we recognize that an opinion is not a fact. -
motorhead43026 wrote: »
@Toolfan66, this is coming up for auction soon.
Art by (and SIGNED, numbered 138/250 and doodled (flaming skull) in pencil by) Emek, extra-thick flat stock silkscreen poster is in near mint (A- to A-/B+) condition; really nothing more than a fairly small semi-pronounced pinch crease in the right margin and that's pretty much all there is to speak of... a pretty sharp-looking example of Emek's oft-requested "Cyberman" Tool poster from 2006.
It will go for stupid money $3k-$5k if the foil variant my guess would be knocking at $10k -
In a pinch I thought that fuse was ingenious. As long as it is the same value fwiw
If Paul Klipsch made pianos.
^^^ stealin' borrowin' that one!
Meanwhile -- at least in northern New England, it's quite brumous today.
Thanks I had to look up brumous
So what's it mean????Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
I looked it up...it means crappyMain Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
A co-worker gave me this truck many, many years ago (15+) because he liked my truck and saw this at a store.
This truck has all wheel friction drive. You push it and it goes and goes... It was green. I was bored after trying to do some work in the front room sealing those ceiling board joints since they opened up a little. I can't reach any higher without putting my scaffolding back up.
I saw this truck and thought...I've got primer and white spray paints. Do it.
I did ok taping, but I sure wasn't trying to do contest level prepping.
After sanding, priming and painting the white.
Getting the side ready for metalflake blue. I taped it off and then sanded, primed and painted.
This blue is close to what's on my truck. The blue on my truck is micro-metalflake.
I really liked FINNALY painting this diecast truck to look kind-of like my full size one.
From a distance, you can't see the flaws. The flaws will be fixed when I go to paint the black side trim with the chrome center. This diecast even has 3 ridges for that side trim layout. The tailgate has to be detailed also. The front of the hood and one rear side bottom needs more white paint. The windshield trim needs to be chrome along with the the side mirror's fronts. I just saw the rear taillights. I need red too.
Most people just listen to music and watch movies. I EXPERIENCE them. -
soundfreak1 Posts: 2,939
12:32PM
is that another adjustive -
(ASR)
Ya gotta love capitalism. Wish I had thought of that!Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Nice job!
Here's models of the cars I had in high school. Correct colors on both and accessories, but don't look to close at the workmanship as I'm not the model builder I use to be. Hard to paint a straight line at my age.
Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. -
I always wondered what you'd get if you crossed a Rottweiler
with a bat.
Pretty potent Woof Woof I'd say.
Might want to have it tested for any contagious infections though. 🦇😷
Sal Palooza -
Those are some great high school cars for sure.
Your paint jobs look great from here.
@Milito quote;
Found out that Kennedy Space Center has a steady supply of E85 fuel. Very hard to find in Brevard County. Been driving 60 miles for it. Now I can run a E50 blend tunefrom ZFG Tunning. Now I have about 525HP. So much fun on this tune. It breaks all four 275/45/21 loose when it hits second. Pretty sure I'll end up in jail soon.
Post edited by CH46E on -
Explorer ST?
