##$^&@!@#$%%% decimal points (or I just whoopsed! )
ALL212
Rebuilt the xovers for the R200 - pics later. Got the last of the parts in today and got everything on the original boards with a bit of faniglin. Cranked 'er up and tweeters just didn't sound right - very subdued. Figured maybe the new components just needed breakin but nah...somepin' isn't right.
Put 10 ohm resistors in the tweeter circuit instead of 1 ohm. And just out of blind dumb luck I had a pair of slightly used 1 ohm Mills in 12 watt (only needed 5 watt so we're BUILT now!).
Looking closer at the boards I found one of them had a spot of glue on the . for 1.0 and I probably ordered what I saw... BAJEEZUS!!!
Anywho - rebuild done. I do remember not really liking what I heard from them out of the box. These have all new resistors...well, almost all new resistors. New inductor and caps' in the signal path. And, placebo or not, I like this sound without any break in.
Let's blame sand cast resistors... I HATE sandcast resistors. Ugly, nasty beasties...
Aaron
Enabler Extraordinaire
Well done Aaron, but please remember to include pictures, lots of pictures.
All resistors sound the same, you wasted your money.
ya ya...hold yer horses!
pic's next. This recipe called for keeping things within a budget and attempting to use the original circuit board.
Clarity PX caps - piggy backed a 3.9uf on top of a 20uf to make as close to 24uf as possible.
Jantzen air core inductor in the woofer circuit replaced an iron core. This has a bit more dcr than the original.
Mills resistors with now 1 Mundorf as it needed to be at least a 15w job.
I tipped the electrolytics with a .01 Dayton PPT on the bottom as I had four of these laying around.
Since the speaker is an R200 I had plenty of room to work with but still wanted to use the original crossover board.
Kept original wiring
Did not remove the tweeter - no need and I think it's bolted down with 16 penny nails.Aaron
Enabler Extraordinaire -
Here’s the pair.
And the replacement resistor in place.
Aaron
Ya...but they're ugly. Ya... I know I can't see them but I KNOW THEY ARE THERE!!!
Aaron
I've seen his basement I need no pictures...
I did fill in the well and I took the boards off the windows...
Bathtub was...ok...I'll quit!
Aaron
I guess we'll have to start watching you, sign off before you do anything.
Nice work.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Another job well done!
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
OH! and I put Streetwires ZeroNoise mat on the woof's. Outside of the stamped sheet metal risers and around the base next to the magnets.
And I feel better, sleep sounder, having done so. I think I just covered the benefits of doing such.
Aaron
Very Nice!Home Theater/2 Channel:
dhsspeakerservice.com/ -
Going to call this a success.
Bass is controlled much better. Really amazing how good these sound even drastically off center. You don’t hear the very upper registers but even 90 degrees off center they sound good.Aaron
How do you access the xover in the R200?
Take out the mid-driver. The crossover is located on the bottom of the cabinet. -
the ring around the driver pulls off like a grill- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
