Additional garage at Verb's house!
  • Love the Epoxy floor! I had mine done back in 2011 for 2 grand on my large 2 stall and it's held up fantastic. If ya really want to go down the custom garage rathole, check out Obsessed Garage on YouTube. I got hooked on the wall mount pressure washer vids. he posts since I'm constantly washing my cars. This is my partially installed unit.zlxjvbmamatp.jpg
  • ^^^^^ Very cool! Just watched a couple of his vids! Funny he mentioned he was getting grief from his HOA on some of his design features (they wouldn't let him do roll up doors) - I've totally been through that myself on the whole project!
  • He's doing a series on a garage/building makeover in Atlanta for a guy that essentially gave him an open checkbook. It's a must watch for guys like me that spends all his time in the garage tinkering with their cars.
  • I also watched one of his videos.
    https://www.youtube.com/user/mattmoreman
    Very cool garage!
  • Milito wrote: »
    Very cool garage!
    Very cool! That garage was a contest giveaway too!
  • Garage Floor all fixed!
    Amazing how much dust accumulated on the other side.
    Scratches are all gone!
  • Looks awesome! I was amazed after the guy applied mine and said I could walk on it in 30 minutes. Nothing from the big box stores will outlast the durability of it. Just don't ever put a car on jack stands with angle iron edges on the bottom, it will damage it.
  • charley96 wrote: »
    For sure - I'll start out being really careful, but then the 1st scratch (done by me, not the builder) will be the most painful!
  • Beautiful! If that was my garage floor, it'd be trashed within a year... :D
  • charley96
    edited December 2021
    Mine is looking a little dull on the side I park my daily driver on. There's no way to keep the grit in the tires from not scratching it.
    Need to install an under carriage wash that cleans everything off before you pull in 😝
    The garage is awesome!!
  • The only issue I don't like with my floor is if your spill water on it or it drips from my car, the floor doesn't absorb the water. I have to to sweep it out of blow it out. Besides that I love mine.
  • Milito wrote: »
    A good friend had his floor done and I'll add, on his the water is basically invisible. On his water can make it very slick, I've done the water dance a time or two. In the winter I tread lightly.
  • The company that did mine gave me a floor squeegee to push the water out. The other positive is the winter salt won't eat at the concrete. I thought the 2 grand mine cost was steep but the longevity has proven itself going on 11 years with mine.
  • Milito
    Milito wrote: »
    The surface of ours isn't smooth, we didn't want one that was smooth at our age. That was a concern for us and they put enough flakes in it where it's not slippery when wet. I also didn't want the floor too dark where I couldn't find black bolts or screws on the floor if I dropped them. I do love the way the dark floors look.
    One of there days when after I clean the floor I'll post pictures of what I did to the garage in our new house.
  • VR3 wrote: »
    I do have to be careful, any debris that is attached to the tires will likely scratch the floor!
  • pitdogg2 wrote: »
    Milito wrote: »
    Oh yeah, the old garage has a smooth epoxy finish (I plan to fix that), and have landed on my arse a few times!
  • Milito wrote: »
    Milito wrote: »
    Same here! We had the installer add a layer of texture material (IIRC beads, glass maybe), to give it a non smooth finish.
  • Tiles laid in the breezeway today!
    Pro tip I learned today - thin coat of spray lacquer over the chalk lines to keep em from smudging!
  • Just caught up on this thread.
    Verb, everything looks GRAND! Also love all of your personal touches.
    What kind of car for YOUR garage? Maybe a new Corvette to go with the old Chevy?
    Harry / Marietta GA
  • Thank you sir!
    Almost to the point where I can start moving in stuff. Right now the plan is to put the 59 Bel Air, and the 2 Harleys in there. Some workbenches, and other storage cabinets too. I'll be able to tinker around and wrench on the vehicles if needed.
    In a pinch I can also put the SSR in there, but it would get a bit crowded. So the SSR will stay in the old garage, that way I'll have room in the new place to hang out too. Watch TV and listen to some 2.1 channel music!
  • I like that large tile in that hallway. It looks like it was made for that width. B)
    I just thought about that diamond plate wainscoting you were going to place 3' up the walls I believe it was.
    Are you still planning on putting it up on top of that baseboard?
  • Tony M wrote: »
    Funny you ask, as the Mrs is against it! So we're still negotiating!
  • Happy Wife, happy life. :p
  • Tony M wrote: »
    You got it, but as you know it's a process. She's not too excited about all of my decorating plans either. Lots of neon lights, retro signs, retro tool cabinets, traffic light, gas pump, retro tire inflator, etc. I've got a lot of this stuff staged all over but mostly in the basement and in the old garage. Still looking for a cool retro gas pump and a reasonably priced eco tireflator.
  • verb
    Ugh, my general contractor got Covid! Things were kinda slow past 2 weeks, but they did finish the tilework in the breezeway (sans grout). Now I hope for a speedy recovery.
    Last week I had a buddy come over and touch up the toolbox. Nothing major, just a tiny bit of rust and paint de-lamination along the edges of metal, at the bottom of the box and the lower parts of vertical risers. He ended up exceeding my expectations. Took all the drawers out, sanding and smoothing the nearly the entire front face of the lower box!
    PPG paint codes were still available so it was nearly a perfect match.
    I really wanted to kill the issue so it'll last, for the remainder of my lifetime!
    He's coming back over this week to buff and finish up. I've also cleaned and re-greased the drawer slides prior to re-assembly.
  • verb
    More pics. Tile baseboard installed in the breezeway.
    A bit of a cluttered mess, but drawers are out waiting to be re-installed.
    And a Gladiator maple top workbench assembled!
  • verb
    Been slowly working of the garage, and breezeway. My builders have been AWOL (they're working on another project) so it's been rough to get them over to finish the inside!
    Replacement Door Wall installed. Hung some metal signs above!
    And, hung this neon sign today in the breezeway!
  • verb
    Found some vintage service parts cabinets to hang above the windows! And, only 5 more drawers to go on the Toolbox, I de-greased all of the slides (40 of em) and re-greased everything!
