Unusual HiFi products from the past.
I was gonna say badger!
That would be just the thing for a hifi equipped with EV Wolverine speakers, you know?
DSC_7165 (2) by Mark Hardy, on Flickr -
^^^ Also useful for swabbing the decks.
Decks? Would that be Reel to reel, 8-track or cassette?Stan
Main 2ch:
HT:
Other stuff:
Decks of ships can be swabbed while not cleaning records. A dual purpose cleaner.
^^^ Also useful for swabbing the decks.Decks of ships can be swabbed while not cleaning records. A dual purpose cleaner.
I feel strangely compelled to note, as sort of a countermelody to the deck motif, that the aforementioned EV "Wolverine" drivers can also, apparently, be pressed into service in the percussion section of, perhaps, financially-strapped community orchestras.
https://worldradiohistory.com/Archive-All-Audio/Archive-HiFI-Stereo/70s/HiFi-Stereo-Review-1977-08.pdf -
This is actually a fairly recent component, but it is definitely unusual. On first look it appears to be a small combination of a reel to reel deck and a CD player, which in and of itself is certainly strange. What audio company in its right mind would couple those two opposite ends of the spectrum mediums. Well, the strangeness goes even further. Instead of the standard 1/4" open reel tape this machine uses 1/8" tape. This means the entire tape transport had to be completely redesigned to use the same tape as cassettes used, but on an open reel. The tape reels had to be remanufactured, tape cut to the proper width, heads designed and manufactured. The single reel of supplied tape is the only tape that will ever play on the machine. A tremendous amount of building for a totally bizarre product. -
Exactly! What were they thinking?
SeleniumFalcon wrote: »
Yup, I remember those -- it would have been interesting indeed to encounter one in the... umm...flesh, though. They came and went quite quickly.
Techmoan recently did a tear down of this, the reel to reel section is very cleverly re-using a standard cassette mechanism.-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
High Fidelity - July 1980
... for some reason, this makes me think of this
https://worldradiohistory.com/Archive-All-Audio/Archive-HiFI-Stereo/80s/HiFi-Stereo-Review-1985-04.pdf
Did these folks ever advertise anywhere but the classified section of High Fidelity and Stereo Review? I just did a quick search and didn't easily see ads in, e.g., some of the tape recorder magazines of the golden age @ worldradiohistory.com
One of the claims of the Omnisonic 801 (made by Omnisonix, Ltd) was that one possible benefit would be realized with speakers placed within 12" of each other, side by side. And in the Jan 1980 issue of Stereo Review they tried that and were amazed by how wide the sound stage was. They felt if, for some reason, speakers couldn't be separated this component would help ameliorate the limitations. I believe some boomboxes would later include this circuit.
It's funny but I have a friend who made a fairly successful living using that kind of voice cancelling device to make practice recordings for student opera singers. -
"The IR2100 Image Restoration Control by Sound Concepts is almost as dazzling as the Carver and has several unique advantages. First, it is small enough to fit in your hand, and since it is connected to your system by a 12-foot cord, you can make all adjustments (as well as a direct comparison between processed and unprocessed sound) right in your listening chair. Second, it’s more adjustable than the Carver. To a great extent, you can tune the unit to your speaker location rather than the converse, which removes much of the hassle. Third, this system is at its best with the speakers near rear walls (not side walls), which is usually more convenient than Carver’s away-from-all-walls recommendation. The Sound Concepts unit is also available at Melody Shop for $250."
Now those are fascinating.
Some details please sir? -
Those are Sony SS-R10 electrostatic speakers 1995-1999.
I did not know there were ever any Sony electrostatic loudpeakers!
mhardy6647 wrote: »I did not know there were ever any Sony electrostatic loudpeakers!
Say whaat? -
