Cary Audio SLP-05 question..
one other thing I have noticed over the last few days is how lower volume friendly my system has become, and 9:00 is plenty loud enough, it really rocks the house, but push it to about 10:00 it really takes it well with ease, I know there is plenty of headroom to take more but really there is no reason to push it beyond 9:00 IMO.
ME TOO!
I never gave this any thought until I read a comment that Marvin made about there being benefits of using the full real estate of the volume knob
Honestly, I still don't get it and would like someone . . . to Splain it Lucy!!
I have not been able to find a decent explanation on line . . . and in all honesty, I have not tried very hard
Apparently, there's a outfit in the UK that makes these attenuators for a reasonable price
Maybe, The DOC @mhardy6647 will chime-in with a layman's terms explanationAC Regenerator PS Audio PerfectWave Power Plant 10
Source Lumin U1 Mini into Lampi Baltic 4
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Wait a minute
Did no one mention one of the biggest upgrades on the 05?
The rectifier tube.
Phillip mini watt.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
ME TOO!
Same here! I rarely go beyond 9:00, and at 10:00 it is plenty loud for me.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Wait a minute
The rectifier tube.
Phillip mini watt.
I have a Tube Doctor in mine right now, the previous one went bad, and @GlennDog , now you are encouraging me to go for it!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Wait a minute
The rectifier tube.
Phillip mini watt.
Ok were was it made?
That name was used but the tubes were made by Amperex, Mullard, Mazda, a few plants in Belgium and one or two in the USA.
I’ll post a pic of the box when I get home
And tube please, any numbers on tube.
Thx -
Thx
I’ll see what I can doMagico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
You guys are funny 🤣Gustard X26 Pro DAC
Here is my Miniwatt
From an old 2018 post I made.
IMO Holland made (Phillips) with double D getters are the best GZ34/5AR4. Either metal base (typically uber pricey) or look for the Black base with metal base innards. I had Holland made Black base with metal base innards that were branded Mullard. GB manufactured Mullard are fine too.
Site with pics/descriptions.
http://www.tube-classics.de/TC/Tubes/Valvo GZ34/GZ34.htmSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote: »From an old 2018 post I made.
Which one is mine? The metal base correct?Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Yes, yours is the metal base, and they are pricey..
That is why you can have the same tube made in the same plant, same day, branded six different ways and have just as many price levels.
That tube you have joey is a nice tube, yet not many had that kind of coin these days as prices had escalated.
Excellent. I was 99% sure I had what was referred to as the metal base version but I wasn’t sure if metal base referred to the actual base or some platform or aspect of the tube construction.Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
Oh my goodness... is this what they go for now?
https://www.ebay.com/itm/254888898285?hash=item3b588feeed:g:Z7oAAOSwAuVgQJFAMagico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
https://www.ebay.com/itm/333948078551?hash=item4dc0db49d7:g:NWEAAOSwmnNga36b
Maybe this one is closer sport -
Before some folks did thorough research, they thought only metal base had the best innards. At one time, you could get the black base with metal base innards much cheaper. I paid ~ $75 each for two NOS GZ34 black bases with metal base innards.
Similar thing happened with the Bendix 6900 tube. The 6900 tube was a higher quality more durable 5687 used for missiles and military equipment. 5687, think of ModWright gear. Three years or so ago, Bendix 6900's could easily fetch $800 a pair. MU Engineering bought the Bendix Tube Division. They rebranded existing stock and continued to manufacture tubes with Bendix tooling. Before folks learned that you could buy MU6900's for $300 a pair. Norm (RIP) and I could not detect any audible difference between the MU6900 and Bendix 6900. They had identical innards.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
When one refers to a "coin base" tube, does that imply the metal base? Or metal innards?AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
It implies that the base is thin like stacked coins or wafers.
Loks like this
https://www.ebay.com/sch/i.html?_nkw=6sn7+coin+base&_trksid=p2380057.m4084.l1313 -
Imagine my confusion when these tubes that came with my Cary 98 were referred to as coin based …
It’s true, when Ivan speaks, people listen!
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Those should be put to use and report back.
Old metal base stuff is highly regarded.
I've not had the pleasure of any old good stuff like that.
That Cary 98 was my very 1st foray into the tube world. With the 6sn7Ws in the front most position, the SQ was sublime.
If i could find 4 more at an "affordable" price I'd roll 'em all in the Cary 05. Good luck, right?
If I switch my cabling to all SE, I can get-by with using the 2 W's in the pic, in the sweet spotAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
Gotcha!
Maybe I will slide in my Sylvania’s today, all this tube talk as got me wondering what awaits..
Before you do
Listen to a couple of your favorite songs, note a few details
Another suggestion, once tubes are swapped, before listening, let the pre/tubes warm up for about 20-30 minutes
Enjoy … I’m excited for you2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »Before you do
Thanks!! And will definitely do.
So I didn’t swap out the 6SN7’s yet but I did swap out the rectifier tube with a NOS Sylvania tube, it’s a fat bottle tube, definitely larger than the Sovtek I took out of it..
I also put in the RAL cable. I also moved some things around, Joey was right about the pre leaving marks on the power supply with its feet, I buffed most of the circles off, I ended up putting them on their own shelf, I am pretty sure I can polish out the rest of the circles but I will do that another day..
Ooooo I see some new caps after the warranty period. 🤣🤣🤣
Oh and maybe found Bob Carvers transformers...
I ked I ked
Sweet Nudie's 👍👍 -
“Found bob carver’s transformers”, lolololol!
Pre looks good brother, enjoy it! I am swooning over it. I would love to own one someday2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
Any SQ diff? might be a little early to tell . . . .AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12
