Post a picture... any picture
@mhardy6647 Isn't there a potential for negative effects/interference/distortion by having the internal speaker output wires running this close to a transformer?
Should be in the "baby show me your guts" discussion but, wow that is pretty close. What amp is that?Gustard X26 Pro DAC
Buffalo Mountain TNMojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
It's this: https://www.balanced.com/vk80i-integrated-amplifier -
If BAT is doing that they must shield the crap out of it somehow. Invisible Aluminum?Gustard X26 Pro DAC
Whiskey, Vodka or Tekillya?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Probably Wodka.Gustard X26 Pro DAC
― Aleksandr Solzhenitsyn -
Oh, the humanity:
One of the benefits of a toroidal transformer is that the lines of magnetic flux are focused inward towards the center of the toroid instead of radiating outward. If the speaker wires were draped over the top of the toroid that would be poor design.
Correct, it's highest in the center, but the magnetic field does exist outside. Following the round contour of the transformer isn't the best choice. It would have been better to put the transformer at the side of the enclosure to keep wiring away from it. Side issues is that the enclosure's center-of-gravity is on the side.
Well... the idea of the toroidal PT is to minimize magnetic leakage -- so it shouldn't be as big a deal as it might be for a traditional "E-I" type PT.
Oh, the humanity:
Help! I can't breathe...
I know you're limited on space but I also know you could never make a stack like this. Never.
I wonder WHY the owner had to do this. The owner doesn't even have room for the TT's cover... wow.
As a side note, it really bothers me that on a $10k integrated they appear to have used some of the cheapest most generic looking binding posts I've seen:
I can't imagine buying a $4k SA-KI Ruby and then putting a cheap Pioneer turntable on top of it like that. Cruel and unusual. -
There are no words.
Is that a Dodge Diplomat reboot or a Ford Fairmount reboot?
Yes.
or if you consider Projective Geometry:
In projective geometry, any pair of lines always intersects at some point, but parallel lines do not intersect in the real plane. ... Also, if any pair of lines intersect at a point on the line at infinity, then the pair of lines are parallel. Every line intersects the line at infinity at some point."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
... and then there's Riemann (Riemannian) geometry.
https://encyclopediaofmath.org/wiki/Riemannian_geometry -
mhardy6647 wrote: »... and then there's Riemann (Riemannian) geometry.
That dude was coached (poorly). He really likes a bitter IPA.
