Ran a 12.0 with the Scat Pack
mantis
mantis Posts: 17,616
Hello everyone,
Had a nice night at the Drag Strip. Pulled a nice 12.0 @ 113.7 MPH which was pretty good. I'm super close to pulled a 11.99 Run with a stock car. I only ran Drag Radials and that was it, the rest of the car is factory stock.
I was car number 2335 , the Explorer was worked a bit and ran very well at 12.9.
Check it out, this was the last run of the night. My son filmed it.
https://youtu.be/K15svDGW5Co
Dan
  • Milito
    Milito Posts: 2,003
    Nice time, congrats!
  • Nesmith98
    Nesmith98 Posts: 225
    Nice run. Have you played around with any tuning software yet?
  • mantis
    Nesmith98 wrote: »
    No , the car is a 2020 and its still under warranty. I only have 8k miles on it which it just turned Friday.
    The only things I'm gonna do to it until it's out of warranty is bolt on stuff. Once I hit the 11's I'll probably stop modifying it. I'm looking for a 11.5 - 11.9.
    Dan
  • Dabutcher
    Dabutcher Posts: 2,622
    That’s kool! Thanks for sharing. Broke anything yet? Peace. D
  • gmcman
    gmcman Posts: 1,864
    Very cool, good run, thanks for sharing.
  • mantis
    Dabutcher wrote: »
    Nah, she's all stock except the back tires for the drag strip. I can run it all day long and not break anything. It's when you start Modding is when you will run into issues.
    Dan
  • TEAforONE
    TEAforONE Posts: 1,100
    That's haulin the groceries! Congrats! It truly amazing running 12.0's in a 2 ton car. I know you're in warranty, a little tune and get that thing to breathe a little better, you should have no problems dipping into the 11's. When you see the second yellow light, let her rip.
  • vmaxer
    vmaxer Posts: 5,121
    Work on the reaction times 😎
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    txcoastal1 Posts: 13,519
    Mantis is right. When you start forking with tuning and performance, you have to start upgrading everything in the chain when your racing
    Most upgrades usually void warranties $$...$$....$$$
  • mantis
    TEAforONE wrote: »
    Thanks. I'm not going to tune it. You have to un lock the PCM and that voids the warranty. There are a few things I can do without tuning and get into the 11's with it.
    I've been drag racing since the 80's . I know how to cut a good light. I could care less about reaction time as I'm practicing my Launch. The car can Spin my Drag Radials pretty easy so I have to re think my Wheel and tire setup. Most guys drop to a 17 or 18 inch wheel 10 inches wide and run a 305 or 315 wide tire Drag Radial or Slick. The Hell cat guys run slicks.
    Dan
  • mantis
    vmaxer wrote: »
    I'm Test N tuning the car so Reaction times don't mean anything to me. If I was bracket Racing I would work the tree. As I said above I've been racing at the Drag Strip since the 80's.
    Dan
  • mantis
    txcoastal1 wrote: »
    Kinda sucks as a Tune would really dial the car in for the up coming Mod's I'm gonna do. I'd love to change the cam, get long tube headers etc but I'm not risking my warranty. You can race it all you want under warranty.
    Mod's I have a JLT Series II CAI system. I took it off for the Track as I wanted to see what the car can do totally stock just on a tire. But I'm not sure I'm gonna use it as I'm probably gonna do a Hellcat Lower Air box and Front inlet tube. This is a nice mod that looks factory stock because you use factory Hellcat parts. That and with a Hell cat drop in Air filter , that should be good for anything I do aferwards.
    Next Mod will be a Throttle Body . very small gain but a gain nonetheless.
    I'm gonna look into Long tube Headers but if that voids my warranty, I will not to that.
    The Exhaust is already a hellcat SRT Exhaust so I don't need to do anything there. There is no power to be gained by messing with it not to mention it sounds incredible stock.
    The Tire and rim combo I select next will be the key to launching the car right. Once that is achieved then Reaction time will come into play for practice If I can get the car perfectly consistent , I'll bracket race.
    The rest of my mod's are my own, not sharing LOL.
    Dan
    All good but you have to upgrade the rear end and drive shaft or it all falls apart
  • mantis
    txcoastal1 wrote: »
    Thats a Hellcat Issue not a Scat pack issue. The Hellcat can twist the Drive shaft when you put a Slick on it and launch it. The Scat pack however doesn't make enough power to twist it apart. I asked around in the Charger and Challenger forums as well as guys at the track and guy who are running in the lower 11's are still on factory Drive shafts. Hellcat owners however all have changed the drive shaft to an aftermarket design.
    Dan
  • mantis
    ZLTFUL wrote: »
    Magnuson - Moss Warranty Act says a manufacturer cannot void your vehicle warranty due to the addition of mods. *Unless* it can be proven that the modification actually caused the damage.
    I don't think it's worth the effort to go through all that madness. Warranty is warranty and the dealer can decide to challenge that when you mod your car. They can twist and turn all they want and make you jump through hoops to get your car serviced. I'm not willing to do all that.
    I think if you want to fully mod your car, then buy used without a warranty or if you have the money to buy new, forgo the warranty and mod the hell out of it.
    I'm not rich and can't afford to fix my car due to damaging it modding it. So I stay in my lane, enjoy what it has to offer, look for safe mod's and stay there. Running 12.0 in the 1/4 already is fun enough. But the racer in me want's to at least beat that time with a 11.99 pass.
    Dan
    audioluvr Posts: 6,020
    Dan, I think you voided your warrantee by racing it. :#
  • mantis
    audioluvr wrote: »
    Not so, dodge encourages you to race it. It has full SRT built in Timers etc.
    Dan
    pitdogg2 Posts: 27,629
