Which one?
F1nut
Just for fun, can you guess which one is stainless steel? Maybe state the reason for your choice too.
No trick here, one of them used to look like the spike at the right.
Middle one would be my answer. Machining is cleaner. More uniform tip.I disabled signatures.
Shinier also. My question is what are the others made of?Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
They're all the same, the one on the right is the original finish, the other two are just different states of polish.
I'd say the one on the left is the same as the one on the right. They all could be stainless as there are different grades but usually the "shinier" ones are chrome plated like the middle as opposed to a chromium alloy (stainless).
LeftYamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream
The one on the left. I see sanding marks on it so the nickel finish may have been removed.
So the middle, or the left one, used to be like the one on the right? 50/50 chance, I reckon.
good ol' homophones
Out of deference to the original topic -- this reminds me of my son, in his paintball days, painstakingly polishing satin-finished aluminum gun marker barrels (and sometimes other parts) with "Mother's Mag Wheel Polish" and a Dremel.
Side note, did anyone else note the appearance of the F1nut Audiophile Towel? This is used to infuse any object with the ability to enhance audio.I disabled signatures.
Now that you mention it...
I meant to say finish is cleaner, not the machining. I think you could be right Ivan, different states of polish.I disabled signatures. -
The ball is under the middle cone.
My guess would be the middle. What do I win?
An all inclusive trip to F1nuts toe jam -
I don't know which is which, but they would make a great Halloween costume.
I would guess the one in the middle, the tip looks identical to the one on the right.
Ok, time to reveal the SS spike. It's the one on the left. Thanks to all who posted their guess.
The spike on the right is a plated brass Dayton in satin nickel. The middle one started out like the right. I mounted it in a drill chuck and at low speed used 400 grit wet/dry followed by 600, 800 and 1000. The purpose was to try to emulate some stainless steel spikes I have that are no longer available. I realized the Dayton spikes are the same shape/size, so I thought it was worth a try. They are now anchoring a speaker stand for a subwoofer, which sits right next to a speaker stand with the stainless steel spikes. Success!Political Correctness'.........defined
President of Club Polk -
Nice job!
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
GWAR tribute band ? 🤗Sal Palooza -
mrbigbluelight wrote: »
I was thinking Gene Simmons on the 10th End of The Road Tour.See my profile for list of gear. -
What do I win?
Hopefully something cooler than Tom's prize since he was wrong.Expert Moron Extraordinaire
I noticed the tip is deformed on the left spike. Is that because stainless is a softer metal?HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5 -
Easy Runnin wrote: »I noticed the tip is deformed on the left spike. Is that because stainless is a softer metal?
Probably because it has been used before- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
No, SS is considerably harder than brass. The SS spikes came with extremely sharp tips unlike the slighty rounded over tips on the Daytons. The slightly deformed tip on the SS spike in the pic is the result of being rammed through carpet onto concrete.Political Correctness'.........defined
Boy, to walk in on the tail end of a conversation at the water cooler...I disabled signatures.
"And then I said I'd sure like to RAM MY SPIKE THROUGH HER CARPET ONTO HER CONCRETE, IF YOU KNOW WHAT I MEAN!"
"Oh, hey boss!" -
Ya'll are perverts.Political Correctness'.........defined
Hell I'm still trying to figure out if I was right or wrong.Gustard X26 Pro DAC
