Which one?
F1nut
F1nut Posts: 52,138
edited October 2021 in The Clubhouse
Just for fun, can you guess which one is stainless steel? Maybe state the reason for your choice too.
No trick here, one of them used to look like the spike at the right.
    msg Posts: 10,528
    Middle one would be my answer. Machining is cleaner. More uniform tip.
  • BlueFox
    BlueFox Posts: 15,250
    Shinier also. My question is what are the others made of?
    pitdogg2 Posts: 27,537
    They're all the same, the one on the right is the original finish, the other two are just different states of polish.
    audioluvr Posts: 6,007
    I'd say the one on the left is the same as the one on the right. They all could be stainless as there are different grades but usually the "shinier" ones are chrome plated like the middle as opposed to a chromium alloy (stainless). :D
  • Milito
    Milito Posts: 2,003
    Left
  • Nesmith98
    Nesmith98 Posts: 225
    The one on the left. I see sanding marks on it so the nickel finish may have been removed.
  • jdjohn
    jdjohn Posts: 3,415
    So the middle, or the left one, used to be like the one on the right? 50/50 chance, I reckon.
    mhardy6647 Posts: 35,359
    edited October 2021
    jdjohn wrote: »
    good ol' homophones ;)
    Out of deference to the original topic -- this reminds me of my son, in his paintball days, painstakingly polishing satin-finished aluminum gun marker barrels (and sometimes other parts) with "Mother's Mag Wheel Polish" and a Dremel. :#
    msg Posts: 10,528
    Side note, did anyone else note the appearance of the F1nut Audiophile Towel? This is used to infuse any object with the ability to enhance audio.
    msg Posts: 10,528
    Now that you mention it...
    I meant to say finish is cleaner, not the machining. I think you could be right Ivan, different states of polish.
  • Hermitism
    Hermitism Posts: 4,340
    The ball is under the middle cone.
    treitz3 Posts: 20,205
    My guess would be the middle. What do I win?
    edited October 2021
    treitz3 wrote: »
    An all inclusive trip to F1nuts toe jam
    Viking64 Posts: 7,696
    I don't know which is which, but they would make a great Halloween costume.
  • Willow
    Willow Posts: 11,305
    Hermitism wrote: »
    Only if he waxes his balls
  • invalid
    invalid Posts: 1,547
    I would guess the one in the middle, the tip looks identical to the one on the right.
    F1nut Posts: 52,138
    Ok, time to reveal the SS spike. It's the one on the left. Thanks to all who posted their guess.
    The spike on the right is a plated brass Dayton in satin nickel. The middle one started out like the right. I mounted it in a drill chuck and at low speed used 400 grit wet/dry followed by 600, 800 and 1000. The purpose was to try to emulate some stainless steel spikes I have that are no longer available. I realized the Dayton spikes are the same shape/size, so I thought it was worth a try. They are now anchoring a speaker stand for a subwoofer, which sits right next to a speaker stand with the stainless steel spikes. Success!
    SCompRacer Posts: 9,147
    Nice job!
  • Viking64 wrote: »
    GWAR tribute band ? 🤗
    nooshinjohn Posts: 26,058
    There are no homophones here... live and let live. :D
  • TEAforONE
    TEAforONE Posts: 1,099
    edited October 2021
    Viking64 wrote: »
    I was thinking Gene Simmons on the 10th End of The Road Tour.
  • Jstas
    Jstas Posts: 14,998
    What do I win?
    Hopefully something cooler than Tom's prize since he was wrong.
    Expert Moron Extraordinaire
  • I noticed the tip is deformed on the left spike. Is that because stainless is a softer metal?
    HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
    VR3 Posts: 29,626
    Probably because it has been used before
    F1nut Posts: 52,138
    No, SS is considerably harder than brass. The SS spikes came with extremely sharp tips unlike the slighty rounded over tips on the Daytons. The slightly deformed tip on the SS spike in the pic is the result of being rammed through carpet onto concrete.
    msg Posts: 10,528
    Boy, to walk in on the tail end of a conversation at the water cooler...
    Clipdat Posts: 13,100
    edited October 2021
    "And then I said I'd sure like to RAM MY SPIKE THROUGH HER CARPET ONTO HER CONCRETE, IF YOU KNOW WHAT I MEAN!"
    "Oh, hey boss!"
    F1nut Posts: 52,138
    Ya'll are perverts.
    Ya'll are perverts.
    Card carrying...
    Hell I'm still trying to figure out if I was right or wrong.
