Help with 2.3tl inside left sp not working
jbail2011
Hi all. I could use some help fixing my speakers. I bought this pair of SDA SRS 2.3tl speakers and am really excited about them. I noticed the right side dominates the sound stage. It seems the 4 speakers on the inside side of the left speaker are not working. I pulled each driver to be sure they were connected and they were. The SDA drivers are working.
I removed the passive radiator and found the caps on the crossover are loose and hanging. I pulled the crossover to look for any obvious issue and, other than the hanging caps, all I can see is green powder shown in the picture below.
Anyone have any idea why these aren’t working?
Polk Audio SDA SRS 2.3 TL
Polk Audio SDA 2B TL mod
Carver M 1.0 MK2 Opt 2 x2
Carver CT Seven Preamp
Bluesound Node 2i
Bluesound Node 2i
What a disaster!
The green parts are resistors. I suspect the powder means that resistor either got really hot or is fully cooked, but they are in the high frequency circuit.
Since you stated some or all of the caps are hanging off you likely have a broken solder joint or even a broken cap lead.
President of Club Polk -
That poor circuit board! That's alot of weight just hanging around! Plus never install caps on resistors or smoother resistors.
Those resistors actually come that way, looks like mundorf mox, the little white powder substance that is.
If you plan to run that build, that way, you need to make a separate board to secure the caps to and then run the wires to the circuit board.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Since you pulled the crossovers out did you try switching them to see if the issue follows?
That’s a great suggestion! Thank youWhat a disaster!
I always appreciate your feedback f1. I will go over the board the best I can. I’m on uncharted territory. I’ll need to learn how to do this.That poor circuit board! That's alot of weight just hanging around! Plus never install caps on resistors or smoother resistors.
Thank you vr3. Can I extend the wires for the caps to bundle them together off the board?
Bluesound Node 2i -
yes you can. Twist together and solder -
Yes, you can add leads to the caps, keep it as short as possible but still with some slack built in.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Also I would highly recommend changing the resistors to Duelund, Path Audio or the newer Mundorf series with the heat sinks, those CMR caps will drastically out perform a MOX resistor.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Noted thank you!
Noted thank you!Polk Audio SDA SRS 2.3 TL
Bluesound Node 2i -
The right crossover is in much better shape.
They have different resistors and the caps are stacked in a different order… 🤔Polk Audio SDA SRS 2.3 TL
Bluesound Node 2i -
Those caps are way too big for the board. Should have never been done.
You need to use the same resistors in both crossovers and that inductor should not be hanging off the edge. Somebody needs to turn in their soldering iron.Political Correctness'.........defined
I’m at a loss as to what to do. How do I accommodate these caps? Is there a better board I can use to rebuild?Polk Audio SDA SRS 2.3 TL
Bluesound Node 2i -
I would dump anything electrical that is made in Britain, but that's just me.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
The cmr caps are amazing, but they need a good point to point network versus Stacked like a mountain on a circuit board- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I think I found the problem. I found this when I was touching up the solder.
Bluesound Node 2i -
nooshinjohn wrote: »I would dump anything electrical that is made in Britain, but that's just me.
I have a triumph spitfire. I am aware 😂Polk Audio SDA SRS 2.3 TL
Bluesound Node 2i -
That is definitely a problem. Whomever did those crossovers should hang their head in shame.Political Correctness'.........defined
Clarity makes excellent products.Political Correctness'.........defined
This fixed the problem and the speakers sound great! Now I need to match the resistors but more importantly fix the capacitor situation. Can someone please tell me specifically what I need to do? Is there a certain board I need to buy? Is there a way to bundle with zip ties and extensions? What’s the best practice here?Polk Audio SDA SRS 2.3 TL
Bluesound Node 2i -
I would just match what was done with the right crossover only secure them big caps with zip ties. You can drill holes in the board as long as you don't damage any traces. Also most here like to install the resistors on the back side of the board if possible to keep their heat away from the caps.Gustard X26 Pro DAC
https://forum.polkaudio.com/discussion/118701/gimpod-sda-boards-for-2-3
i do not think gimpod boards are still available. you may search and see if you can find a pair. -
cincycat13 wrote: »https://forum.polkaudio.com/discussion/118701/gimpod-sda-boards-for-2-3
I agree...someone may have stashed a pair
Open a:
WTB-Gimpod Boards
Good luck2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »cincycat13 wrote: »https://forum.polkaudio.com/discussion/118701/gimpod-sda-boards-for-2-3
Open a:
WTB-Gimpod Boards
Good luckcincycat13 wrote: »https://forum.polkaudio.com/discussion/118701/gimpod-sda-boards-for-2-3
These are gimpod boards.Polk Audio SDA SRS 2.3 TL
Bluesound Node 2i -
Open a:
WTB-Gimpod Boards
Agree they are, the MASSIVE 400V caps make it look tiny....
Do they make the CMR's in 200v ? I personally have not seen any but I must admit I have not put effort into finding them. -
Open a:
WTB-Gimpod Boards
ClarityCap makes the CSA line which are 250V. Good capacitors that are sized more appropriately. -
Open a:
WTB-Gimpod Boards
Yes I'm familiar with the lower line caps. -
Open a:
WTB-Gimpod Boards
What am I supposed to do with these caps to straighten this out?Polk Audio SDA SRS 2.3 TL
Bluesound Node 2i -
You have some of the best caps on the market, I'd find a way to extend the leads, zip tie to a board if that's what it takes. Where do you live?
You can do as Ivan suggests or build point to point crossovers. Here's a few pics to give you an idea.
Or you can create a stack board on top of Gimpod's board like Trey has done for some of his projects2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I’m in Charlotte, NC
Thank you very much for the pics. Great idea!
Bluesound Node 2i
