Help with 2.3tl inside left sp not working
Hi all. I could use some help fixing my speakers. I bought this pair of SDA SRS 2.3tl speakers and am really excited about them. I noticed the right side dominates the sound stage. It seems the 4 speakers on the inside side of the left speaker are not working. I pulled each driver to be sure they were connected and they were. The SDA drivers are working.
I removed the passive radiator and found the caps on the crossover are loose and hanging. I pulled the crossover to look for any obvious issue and, other than the hanging caps, all I can see is green powder shown in the picture below.
Polk Audio SDA SRS 2.3 TL
Polk Audio SDA 2B TL mod
Carver M 1.0 MK2 Opt 2 x2
Carver CT Seven Preamp
Bluesound Node 2i
    F1nut Posts: 51,748
    What a disaster!
    The green parts are resistors. I suspect the powder means that resistor either got really hot or is fully cooked, but they are in the high frequency circuit.
    Since you stated some or all of the caps are hanging off you likely have a broken solder joint or even a broken cap lead.
    VR3 Posts: 29,425
    That poor circuit board! That's alot of weight just hanging around! Plus never install caps on resistors or smoother resistors.
    Those resistors actually come that way, looks like mundorf mox, the little white powder substance that is.
    If you plan to run that build, that way, you need to make a separate board to secure the caps to and then run the wires to the circuit board.
  • monepolk
    monepolk Posts: 1,154
    Since you pulled the crossovers out did you try switching them to see if the issue follows?
  • jbail2011
    jbail2011 Posts: 102
    monepolk wrote: »
    That’s a great suggestion! Thank you
    What a disaster!
    I always appreciate your feedback f1. I will go over the board the best I can. I’m on uncharted territory. I’ll need to learn how to do this.
    VR3 wrote: »
    Thank you vr3. Can I extend the wires for the caps to bundle them together off the board?
    Bluesound Node 2i
    pitdogg2 Posts: 27,034
    edited June 2021
    jbail2011 wrote: »
    yes you can. Twist together and solder
    VR3 Posts: 29,425
    Yes, you can add leads to the caps, keep it as short as possible but still with some slack built in.
    VR3 Posts: 29,425
    Also I would highly recommend changing the resistors to Duelund, Path Audio or the newer Mundorf series with the heat sinks, those CMR caps will drastically out perform a MOX resistor.
  • jbail2011
    VR3 wrote: »
    Noted thank you!
    jbail2011 wrote: »
    Noted thank you!
    Bluesound Node 2i
  • jbail2011
    They have different resistors and the caps are stacked in a different order… 🤔
    Bluesound Node 2i
    F1nut Posts: 51,748
    Those caps are way too big for the board. Should have never been done.
    You need to use the same resistors in both crossovers and that inductor should not be hanging off the edge. Somebody needs to turn in their soldering iron.
  • jbail2011
    I’m at a loss as to what to do. How do I accommodate these caps? Is there a better board I can use to rebuild?
    Bluesound Node 2i
    nooshinjohn Posts: 25,914
    I would dump anything electrical that is made in Britain, but that's just me.
    VR3 Posts: 29,425
    The cmr caps are amazing, but they need a good point to point network versus Stacked like a mountain on a circuit board
  • jbail2011
    I think I found the problem. I found this when I was touching up the solder. pkd8myed6myi.jpeg
    Bluesound Node 2i
  • jbail2011
    I have a triumph spitfire. I am aware 😂
    Bluesound Node 2i
    F1nut Posts: 51,748
    jbail2011 wrote: »
    That is definitely a problem. Whomever did those crossovers should hang their head in shame.
    F1nut Posts: 51,748
    Clarity makes excellent products.
  • jbail2011
    This fixed the problem and the speakers sound great! Now I need to match the resistors but more importantly fix the capacitor situation. Can someone please tell me specifically what I need to do? Is there a certain board I need to buy? Is there a way to bundle with zip ties and extensions? What’s the best practice here?
    Bluesound Node 2i
    audioluvr Posts: 5,905
    I would just match what was done with the right crossover only secure them big caps with zip ties. You can drill holes in the board as long as you don't damage any traces. Also most here like to install the resistors on the back side of the board if possible to keep their heat away from the caps.
  • cincycat13
    cincycat13 Posts: 888
    https://forum.polkaudio.com/discussion/118701/gimpod-sda-boards-for-2-3
    i do not think gimpod boards are still available. you may search and see if you can find a pair.
    txcoastal1 Posts: 13,511
    cincycat13 wrote: »
    I agree...someone may have stashed a pair
    Open a:
    WTB-Gimpod Boards
    Good luck
  • jbail2011
    txcoastal1 wrote: »
    cincycat13 wrote: »
    Open a:
    WTB-Gimpod Boards
    Good luck
    cincycat13 wrote: »
    These are gimpod boards.
    Bluesound Node 2i
    jbail2011 wrote: »
    txcoastal1 wrote: »
    cincycat13 wrote: »
    Open a:
    WTB-Gimpod Boards
    Good luck
    cincycat13 wrote: »
    Agree they are, the MASSIVE 400V caps make it look tiny....
    Do they make the CMR's in 200v ? I personally have not seen any but I must admit I have not put effort into finding them.
  • joebass3
    joebass3 Posts: 311
    jbail2011 wrote: »
    txcoastal1 wrote: »
    cincycat13 wrote: »
    Open a:
    WTB-Gimpod Boards
    Good luck
    cincycat13 wrote: »
    ClarityCap makes the CSA line which are 250V. Good capacitors that are sized more appropriately.
    joebass3 wrote: »
    jbail2011 wrote: »
    txcoastal1 wrote: »
    cincycat13 wrote: »
    Open a:
    WTB-Gimpod Boards
    Good luck
    cincycat13 wrote: »
    Yes I'm familiar with the lower line caps.
  • jbail2011
    jbail2011 wrote: »
    txcoastal1 wrote: »
    cincycat13 wrote: »
    Open a:
    WTB-Gimpod Boards
    Good luck
    cincycat13 wrote: »
    What am I supposed to do with these caps to straighten this out?
    Bluesound Node 2i
    You have some of the best caps on the market, I'd find a way to extend the leads, zip tie to a board if that's what it takes. Where do you live?
    F1nut Posts: 51,748
    jbail2011 wrote: »
    You can do as Ivan suggests or build point to point crossovers. Here's a few pics to give you an idea.
    Or you can create a stack board on top of Gimpod's board like Trey has done for some of his projects
  • jbail2011
    I’m in Charlotte, NC
    jbail2011 wrote: »
    Thank you very much for the pics. Great idea!
    Bluesound Node 2i
