15 inch sub box designs
Just picked up a digital designs redline700 15 inch sub, dual 4 ohm. Going to be running it on an alpine amp that pushes 1000 [email protected] Manufacturer only reccomends ported enclosures, and anywhere from 3-5 cu/ft for box volume. Anyone ever build a box with similar parameters? I wanna keep it at the smaller end, any suggestions?
  • rooftop59
    rooftop59 Posts: 7,567
    This isn’t much of a car audio site anymore: I would recommend hitting up some other forums!
    Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SR250; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
    Game Room 5.1.4: Denon AVR-X4200w; Sony UBP-x700; Definitive Technology Power Monitor 700s mains, CLR-3000 center, StudioMonitor 350surrounds, ProMonitor 800 atmos x4; Sub - Monoprice Monolith 15in THX Ultra
    Bedroom 2.1
  • seabeerob213
    seabeerob213 Posts: 1,838
    rooftop59 wrote: »
    Figured as much but no harm in asking.
    F1nut Posts: 47,644
    You should consult T_Unit616.
    msg Posts: 7,222
    Who's that, Jesse?
    Rob, just curious do you have any space or physical design dimension limitations?
    F1nut Posts: 47,644
  • seabeerob213
    msg wrote: »
    Who's that, Jesse?
    Not too much, going into a 2000 focus wagon Soni have a fairly large trunk area
  • seabeerob213
    msg wrote: »
    Who's that, Jesse?
    So * I* have a fairly large trunk area
  • seabeerob213
    I ordered a gately audio flat pack box, but idk if it will fit the trunk in the new car.
  • RTiguy
    RTiguy Posts: 1
    @seabeerob213 I'm so tired! You're in car audio I thought this was Polk HTR. Sorry bud!
  • gp4jesus
    gp4jesus Posts: 1,883
    edited May 2021
    @seebeerob213 Did you ever build the sub?
    You did not specify sealed or ported Off the top of my head, sealed - 2-2.5; ported - minimum 3 cu ft closure w/3” diameter 15-20” in length.
    You did not mention performance expectations such as F3. WinISD is free to use to model most any driver.
    Samsung 60" UN60ES6100 LED
    Outlaw Audio 976 Pre/Pro
    Samsung BDP, Dish Rcvr, Phillips CD chgr, various game consoles
    Canare 14 ga - LCR tweeters inside* & CC outside
    BJC 10 ga - LCR mids, inside* & out
    8 ga Powerline - LR woofers, inside* & out
    *soldered
    LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged” Mids - 981
    CC: Rotel RB981 -> Bi-amped CSi A6
    5 Subs: Sunfire True Sub Sig -> LFE & CC; 4 Audio Pro Evidence -> “Corners”
    Surrounds: Rotel 981 -> AR 12 ga -> RTi A3
    3 dedicated 20A feeds; APC H15; 4 Furman Miniport 20s
  • seabeerob213
    gp4jesus wrote: »
    I did, I used gately audio's flat pack 15inch 4 cubic foot ported box, added some dynamat to bracing and the baffle and the wall directly behind the woofer, used speaker spikesnto keep it from sliding, painted it with a thick coat of bed liner. Sounded amazing, I did end up getting the sub pretty hot, I could smell it, but it still plays and sounds great, and moves freely, but I have the sub out of the car now after needing trunk space while helping an ex find homes for Ukrainian refugees out here. It's a big heavy sub, I don't wanna carry it back out, and my mpgs went up by like 4 😂. Now I'm getting ready to sell the car and gonna rip out most of the system, so it's getting left in the closet till I move back stateside.
  • rooftop59
    That is a great and kind thing to hear. Peace be with you, Rob.
    Bedroom 2.1
  • seabeerob213
    rooftop59 wrote: »
    Thanks man
