15 inch sub box designs
Just picked up a digital designs redline700 15 inch sub, dual 4 ohm. Going to be running it on an alpine amp that pushes 1000 RMS@4ohm. Manufacturer only reccomends ported enclosures, and anywhere from 3-5 cu/ft for box volume. Anyone ever build a box with similar parameters? I wanna keep it at the smaller end, any suggestions?
    pitdogg2 Posts: 27,769
  • rooftop59
    rooftop59 Posts: 8,120
    This isn’t much of a car audio site anymore: I would recommend hitting up some other forums!
    Game Room 5.1.4:
    Bedroom 2.1
  • seabeerob213
    seabeerob213 Posts: 1,843
    rooftop59 wrote: »
    Figured as much but no harm in asking.
    F1nut Posts: 52,298
    You should consult T_Unit616.
    msg Posts: 10,621
    Who's that, Jesse?
    Rob, just curious do you have any space or physical design dimension limitations?
    F1nut Posts: 52,298
  • seabeerob213
    msg wrote: »
    Who's that, Jesse?
    Not too much, going into a 2000 focus wagon Soni have a fairly large trunk area
  • seabeerob213
    msg wrote: »
    Who's that, Jesse?
    So * I* have a fairly large trunk area
  • seabeerob213
    I ordered a gately audio flat pack box, but idk if it will fit the trunk in the new car.
  • RTiguy
    RTiguy Posts: 1
    @seabeerob213 I'm so tired! You're in car audio I thought this was Polk HTR. Sorry bud!
  • gp4jesus
    gp4jesus Posts: 2,019
    edited May 2021
    @seebeerob213 Did you ever build the sub?
    You did not specify sealed or ported Off the top of my head, sealed - 2-2.5; ported - minimum 3 cu ft closure w/3” diameter 15-20” in length.
    You did not mention performance expectations such as F3. WinISD is free to use to model most any driver.
    *all connected w/Premiere ICs
  • seabeerob213
    gp4jesus wrote: »
    I did, I used gately audio's flat pack 15inch 4 cubic foot ported box, added some dynamat to bracing and the baffle and the wall directly behind the woofer, used speaker spikesnto keep it from sliding, painted it with a thick coat of bed liner. Sounded amazing, I did end up getting the sub pretty hot, I could smell it, but it still plays and sounds great, and moves freely, but I have the sub out of the car now after needing trunk space while helping an ex find homes for Ukrainian refugees out here. It's a big heavy sub, I don't wanna carry it back out, and my mpgs went up by like 4 😂. Now I'm getting ready to sell the car and gonna rip out most of the system, so it's getting left in the closet till I move back stateside.
  • rooftop59
    That is a great and kind thing to hear. Peace be with you, Rob.
    Game Room 5.1.4:
    Bedroom 2.1
  • seabeerob213
    rooftop59 wrote: »
    Thanks man
