Polk Audio LSIM 707
Landia
Landia Posts: 5
Hello, I am looking for an amplifier to power a pair of the LSIM 707 speakers. I was looking at this amplifier and would like to know if this amp is a good fit to maximize the power of the LSIM 707 speakers:
https://www.sweetwater.com/store/detail/XLI3500--crown-xli-3500-power-amplifier
Thanks for any advice!
    pitdogg2 Posts: 27,526
    Pass ! Not many fans here for PA amps in a home audio use. you can get a good used 2 channel amp for that kind of money.
  • Landia
    Landia Posts: 5
    With a power rating of:
    Watts/Side @ 8 ohms: 1,000W (Continuous)
  • Emlyn
    Emlyn Posts: 4,858
    edited May 2021
    The Crown amps are designated as public address systems amps for a reason. They're good for pumping out lots of volume for speaker systems that are designed to fill large venues where sound fidelity isn't the primary concern. They're not designed for use as high quality/low background noise amps but do suit their purpose well.
    Even if someone does use a Crown amp for home audio the 3500 model is overkill for power output. The 1500 would be more than enough for the LSiM 707s.
    They do work of course, but are a waste of money for use in the home in my opinion.
  • Landia
    Landia Posts: 5
    Emlyn wrote: »
    The Crown amps are designated as public address systems amps for a reason. They're good for pumping out lots of volume for speaker systems that are designed to fill large venues. They're not designed for as high quality/low background noise amps.
    Do you have recommendation for "Home Audio" amplifiers for the 707s? Thanks!
    Landia wrote: »
    Personally I'd rather have a lower wattage amp with enough high current to drop an elephant. It's not all about the watts, you need good high current to deliver them. You can still have tons of watts and just enough current to deliver them.
    F1nut Posts: 52,132
    All watts are not created equal.
    Pick out a few home audio amps in your budget and we'll be happy to offer our opinions.
  • Landia
    Landia Posts: 5
    edited May 2021
    Below are the amps I am looking at:
    -Peachtree audio 220
    -ROTEL RB-1572
    -Emotiva XPA-2
    -Adcom GFA-5800
    -Adcom GFA-555se
    -ADCOM GFA-5500
    Is there much of a difference between Class A/B amps and Class D amps? Thanks!
    F1nut Posts: 52,132
    My 2 cents.....
    -Peachtree audio 220 - no personal experience, gets good reviews.
    -ROTEL RB-1572 - not a fan of the Rotel house sound.
    -Emotiva XPA-2 - no.
    The next 3 are a bit long in the tooth, so unless serviced expect them to need some work done such as a recap.
    -Adcom GFA-5800
    -Adcom GFA-555se
    -ADCOM GFA-5500
  • rooftop59
    rooftop59 Posts: 8,120
    Landia wrote: »
    -ROTEL RB-1572
    -Emotiva XPA-2
    -Adcom GFA-5800
    -Adcom GFA-555se
    -ADCOM GFA-5500
    What’s the budget?
    Game Room 5.1.4:
    Bedroom 2.1
  • erniejade
    erniejade Posts: 6,321
    What about a used b&k amp or parasound? You should be able to find one that fits your budget. What are you using as a pre and source?
  • marvda1
    marvda1 Posts: 4,964
    Here's a pass labs for an extra $200, you might be able to talk him down a little.
    https://www.audiogon.com/listings/lisaac7c-pass-labs-x150-8-tube
    Puritan PSM156
    F1nut Posts: 52,132
    Great suggestion, but 5/10 condition and local pick up only.
    audioluvr Posts: 6,007
    The guy doesn't even know if it works Marvin. I mean they are REALLY nice amps but I'd be leary as hell of a seller that doesn't even know how to hook up a pair of kraco car stereo speakers and a Goodwill AVR to test if it even works. Could be an awesome deal or an expensive boat anchor.
  • marvda1
    edited May 2021
    sorry, my mistake, didn't drill into the ad. this one i did read. make an offer.
    https://www.audiogon.com/listings/lisaa763-legacy-audio-ultra-high-current-amp-coda-ls96-ls200-pass-solid-state
    Puritan PSM156
  • Emlyn
    Emlyn Posts: 4,858
    I would take a look at the Parasound A23+. I have run an A23 model on the biggest Polk towers for the last few generations and been pleased with the results. The plus model has a little more power than the previous version. Should make better than 200 watts per channel into the 707s.
    May be able to find used or demo models for a discount.
  • rooftop59
    Game Room 5.1.4:
    Bedroom 2.1
  • sgmsmg
    sgmsmg Posts: 556
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
  • rooftop59
    Landia wrote: »
    -ROTEL RB-1572
    -Emotiva XPA-2
    -Adcom GFA-5800
    -Adcom GFA-555se
    -ADCOM GFA-5500
    I like peachtree’s little all in one solutions for the right need, but when I tried a nova220SE, I was disappointed in comparison with my cambridge Azur 851a (an excellent option if you need an integrated). The peachtree sounded a bit sound to my ears, and the DAC was definitely not superior to my stand alone DAC. But I did not test it as just an amp fwiw...
    If you can find a musical fidelity amp for under a grand, I love mine...
    Game Room 5.1.4:
    Bedroom 2.1
  • Emlyn
    Emlyn Posts: 4,858
    rooftop59 wrote: »
    Solid. The new 2250s are backordered until July. Either a lot of people buying them up or supply chain issues there too.
  • marvda1
    Puritan PSM156
    marvda1 wrote: »
    Those were pretty solid amps.
  • skrol
    skrol Posts: 3,476
    My Parasound HCA-1000A (with some mods) pushes the LSi15 pretty well. A HCA-1200ii or bigger Parasound should do even better. I believe the LSi15 is a harder load than the LSiM707.
    Stan
    Main 2ch:
    HT:
    Other stuff:
