List of good RT800 mods?
Hello,
I made this forums account because not only do I love Polk Audio to the point where its an addiction but I also was wondering about some Polk RT800 mods.
See the Polk RT800s are the second best speakers I've ever heard (the best are probably the Monitors with no number after their name they were released in 1992 and pretty rare).
I have them Passively Bi-Amped by my Onkyo TX-NR656 and I have removed the weird fabric finish and painted the wood black instead kinda like the RT800is.
Essentially the last step I'm looking to is modding them entirely in a way where I can improve the sound quality as much as possible, allow the use of Bi-Amp and Mono-Amp, and maybe more cosmetic mods.
I cant think of any that dont invole modding the crossover which I AM WILLING to do but I'd like to do simpler things than that first. I am a techy guy and repaird my Nintendo Switch and both its controllers in under an hour but I value my speakers more go figure haha. I also have little soldering skills.
Any ideas would be greatly appreciated, thanks!
My gear:
  • TCL 75QM7K TV
  • Onyko TX-NR656 AVR
  • RT3000p Fronts
  • CS1000p Center
  • RT35 Side Surrounds
  • RT35 Rear Surrounds
    xschop Posts: 5,185
    Send your crossovers to @wesmassguy. He'll take care of you. Damp the baskets with butyl mat. Put some sound foam behind the mid driver's.
  • ChrisD06
    ChrisD06 Posts: 927
    @xschop Do you mean the acoustic foam pads? Also do I put the foam on the magnet, in the cabinet, or around the butyl mat damping?
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • ChrisD06
    ChrisD06 Posts: 927
    @xschop Also I'm assuming you meant @westmassguy ?
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    xschop Posts: 5,185
    Put inexpensive 1/2" x 6" x 6" open-cell foam pads directly behind Midwoofers on the rear cabinet walls. Put butyl mat or Dyna mat brand on steel frame posts of the baskets.
    Yes, I believe Westmassguy is DHS speaker service and does a great job on crossovers.
  • ChrisD06
    ChrisD06 Posts: 927
    @xschop So do I wrap the mat completely around the baskets? Or do I just cover the metal bars and leave the gaps open?
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    xschop Posts: 5,185
    edited February 2021
    Just on metal bars. Do not block the air passages.
    If you want to cheap out on butyl mat, Home Depot sells a product called U-Seal and it works just as well as Dynamat.
    I have a modded set of RT55 cabinets at the shop....built like tanks and take shrapnel too lol.
  • ChrisD06
    ChrisD06 Posts: 927
    @xschop Alrighty, I wrote down Butyl Mat, Open-Cell 1/2" thick foam, and "give WestMassGuy a call" on my shopping list.
    Last question then I'll quit bothering you haha.
    Does the foam and butyl mat simply absorb vibrations that are unwanted? Or does it have another purpose too?
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    xschop Posts: 5,185
    Butyl mat gets rid of the accompanying "ring" of the stamped steel baskets. The foam absorbs midrange frequencies from rebounding to the back-side of the Midwoofer cone if I recall correctly. I've done to quite a few different speakers and indeed clears up midrange frequencies.
  • ChrisD06
    ChrisD06 Posts: 927
    @xschop Alrighty sweet! I need to take apart my RT800s again tomorrow to fix some of the paint in a spot I missed anyways so I think I'll try to at least do the Butyl Mat then or the Home Depot rip off stuff!
    Thanks a ton! I'll post an update once it's all done!
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    xschop Posts: 5,185
    Post pics. Also might want to grab a small tube of Power-Grab sealant and glue the midwoofer magnets for insurance.
    Maybe someone can chime in and advise on possible interior wiring upgrade.
  • ChrisD06
    ChrisD06 Posts: 927
    @xschop The magnets can fall off? If those things come off then I'm not messing with them at all! I already thought I broke my tweeter after thinking I could remove it and pulling the magnet off. Luckily the design allows it to do that. No clue why Polk made the magnet come off and not the dome+coil and not just the whole assembly.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    xschop Posts: 5,185
    Just don't drop them. There is a possibility of the magnets shifting if dropped on a hard surface. Don't be alarmed, just be careful and proceed. The sound improvements are worth the effort.
  • ChrisD06
    ChrisD06 Posts: 927
    @xschop And if the magnet shifts, the voice coil will start rubbing OR get jammed right? Havent dropped then yet and highly doubt I will. Will probably skip the gluing.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    xschop Posts: 5,185
    Yes, is possible for VC jamming if dropped and magnet shifts. Those Midwoofers would be easy to do while they are face-down and just run a bead around perimeter of top and bottom steel plates that interface with magnet.
  • mantis
    mantis Posts: 17,394
    ChrisD06 wrote: »
    Hello,
    Welcome to the forum. The Material on the front of the RT800's is not cosmetic. You actually lowered the sound quality by removing it. The speaker was designed to have it in place to reduce sound wave reflections off the front of the cabinet. This material would help with the high frequencies if I remember correctly. Back when the that series of RT's where released on the market, I studied them as I was trying to buy the last Gen RT series and missed out. I had the RT1000p's and the rest of the line for a 7.1 setup.
    The RT800's stock are nice speakers but like most of the RT lines up in till the RTia series they all to me just lacked some mid range , slightly harsh up top and slightly loose in the bottom end.
    For the money all these negatives are not negatives, not many speakers in their price points do any of those things better. You have to step up to higher end speakers to get better control.
    So you are absolutely on the right path with the Crossovers, many in here have done upgrades there with great success. This is where your gonna get your most improvements without changing drivers and tweeters.
    Member VR3 is your guy to talk to.
    Dan
  • ChrisD06
    ChrisD06 Posts: 927
    Hey @mantis thanks for the warm welcome! :smile: I had no clue the fabric on the front was for sound. They guy I bought it from was a heavy smoker and had a cat get at the fabric so it was ruined and ugly anyways. I paid 150 Canuck coins for them so I hope I didn't overpay or ruin them. I haven't noticed a difference in sound quality since then, honestly, I noticed a bigger sound difference from Passive Bi-Amping and just switching to Banana Plugs from bare wire which is a whole other story on how my connections would loosen up but you know. I've never noticed the harshness in the tweeter everyone hates. I think my Onkyo is taking care of that with it's music optimizer feature.
    Do I talk to VR3 for crossover, if so why not WestMassGuy?
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • mantis
    I have no idea who WestMassGuy is. VR3 has been a member in here as long as I can remember and has done great work on crossovers. So he's the guy I recommend.
    $150.00 for when new $800 speakers as long as they work and are in good condition I think you made out just fine. $150 for any working good quality good condition speakers is fine in my book. I just purchased a pair of very nice RT16's for $200 and I had a bad driver in one of them. I'm still perfectly fine with the purchase.
    Shame the fabric was ruined but if your not noticing any difference then your probably fine. And since you'll be modifying them I don't think it's gonna matter now.
    Dan
  • ChrisD06
    ChrisD06 Posts: 927
    @mantis Good to know I got a good purchase! Been trying to make the 'RT800cs' and the C is meant to represent custom. Only reason Im modding them is because I wanted the 800is but they were 200 more so my goal has been to smash the i variant with the original. Will contact VR3. I'll do my best to post pics during the process and complete.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • ChrisD06
    ChrisD06 Posts: 927
    @xschop I just remembered to ask this, do I need the open cell foam to be half inch thick or could I stack thinner to make it half inch, or does it not matter on thickness. Also whats the best way to stick them to the cabinet?
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • ChrisD06
    ChrisD06 Posts: 927
    @Kex Holy smokes! If you have the manuals I'd love them! My RT800s have the labels peeling off so my goal is to find an adhesive I could stick them back on with. I tried superglue and it's doing okay but the corners are peeling still so I'm gonna make new labels and put them on. Restoring these puppies to mint condition is my goal and I'm ~90% there.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • ChrisD06
    ChrisD06 Posts: 927
    @Kex Also it's really hard to remove the felt. Unless there's already a rip you can get your fingers under, you might want to skip doing it. Using a knife would work but you might scratch the wood under.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    xschop Posts: 5,185
    Most people use the BH5 in a thicker 4x4 piece stuck to walls behind drivers, but I found the 1/2" 6x6 piece to work. I would suggest not layering up and you can just spray glue it to the foam if you already have some.
  • ChrisD06
    ChrisD06 Posts: 927
    @Kex If you want to get rid of those RT55s I'll take them off your hands! As long as you're located in Canada...
    I don't deal with UPS after they lost my VR headset.
    In all seriousness, if you're in Canada I'll take 'em off your hands. Then I'd finish my 5.0 setup finally!
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • ChrisD06
    ChrisD06 Posts: 927
    @xschop I can only find 1/4" or 1/8" online and in stores so I might need to wait to order some and do that later. Dynamat can still happen!
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    xschop Posts: 5,185
    Just as long as it says "open-cell" foam, you're good to go. .
    Can you post dimensions of the port diameter and length and LxW of the Power Port base?
  • ChrisD06
    ChrisD06 Posts: 927
    @Kex Maybe I could try Bi-poles. I guess you're right about the 55s are rears, honestly never occured they'd be great shed speakers! (Don't worry my shed speakers are taken care of)
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • ChrisD06
    ChrisD06 Posts: 927
    @xschop ARC Port Diameter is 1", Power Port base is 9"x12"
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    xschop Posts: 5,185
    I meant the port tube and it's length. Sorry
  • ChrisD06
    ChrisD06 Posts: 927
    I cant take out the ARC Port tube as I glued it in after they both fell out. (only thing holding them in was tape and the felt) I'm going to estimate it's 5" long maybe 6"
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    xschop Posts: 5,185
    I meant the bottom Power Port tube length and diameter.
