Early B -
VR3
Made templates -
Hugh Jass
What in the world are u talking about?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Your picture.
I tried editing it and resizing it, but eff it - not working...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Phil MaCrackinIf...
Ron loves a film = don't even rent. -
Huh?
(BTW -- clean out your mailbox, dude.)HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
just templates for measurements, the small piece is top and bottom, and the long piece is the front and back....
Was alot easier than I ever imagined...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
It would help if we all knew what we were looking at....:eek: -
For those of you who are trying to figure this thread out, Sid has been commissioned to make some DIY speaker cabinets for me for a pair of full range drivers (Fostex FE166E).
Rock on, Sid.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Ahhh, schweet. Interested in seeing the final product.
PM box is cleaned, sorry - POLK - NEED BIGGER PM BOXES! UGH!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Prototype cabinet Pic 1 -
Probally will decrease the block numbers on the end to just 1 in the middle instead of 2... not really needed...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Protype box pic 2
Shop teacher said the joints is bout as good as it can be done... with the finished product, wont even notice it...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
those have some clean edges for sure well done
Excellent, professional looking. Good job, Sid. The drivers arrived today. Let's go for it!!!HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Wood arrives monday, which means - I start monday or tuesday, depends on what I am going to be doing...
Anyone ELSE want a pair?
LOL, I'm gonna have enough to do two pairs...
Of course, yall have to send Mr. Early 25 dollars
Three words -- TOO F@%KIN' COOL !HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I'm glad you like that... LOL, it was interesting to put something up that didnt have AmpraSid infront of it...
But, all I ask is for is finished pictures, and a review of build quality and sound, more importantly, build quality...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
No problem.
Can I blame you if they end up sounding shitzy?:pHT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
UMM...
NO, because I am going to seal those things down to where it would be almost impossible to have an air leak, and they are right on the mark with internal volume...
No reason it should
Fostex wouldnt recomend a bad enclosure design I dont think...
Everything about these speakers are going to be precise I hope, I am getting a drill press circle cutter thing (the two knives that spin) - so exact cuts on the driver cut out and port holes. The terminal holes will be manually cut, but thats no problem...
Like I said, these SHOULD look like they came from a factory... :cool:- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Test Baffle...
Ok, today was sucky - I planned to use a drill press to cut these holes, but the 'knife cutter' the teacher had only extender out to 2 inches, and since that didnt work - I really didnt feel like having a knife swing around me to cut anything else...
The part the holes are cut on is not the color of the wood, I used a piece I messed up on to cut the test baffle...
here it is, the port hole is slightly to small, so i will have to alter it (and remember to bring the port) Monday...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
The wood color is birch...
*pictured below*- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Aaaahhhh...birch. It'll look real nice with a few coats of stain.
Do your peers think you're crazy for taking pictures of your wood and posting them on the Internet?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I brought that baffle home with me, not carrying the camera to school, hehe...
Yeah, I hope they turn out really well...
I will probally start putting them together sometime next week.... the cutting out didnt go quite as planned.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Lookin' real good there, Sid. You keep up the work and you just might be building cabinets for Polk some day.....:p
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
OK...
One enclosure done - like ready to roll...
The other enclosure is still in iddy biddy pieces...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
picture NUMBA two... no sir, it is not blue (30 seconds must pass before I can post again)- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Picture NUMBA 3 (no sir, it is not stuck in a tree) - 30 seconds must pass before you may post again in ur underwear while in public- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
