Looking under the hood
1363738394042»
    Here is a Wyred 4 Sound, STI-500 integrated amplifier that I picked up recently. This is a later V1 model.
    23 torx screws to take off the cover! You have to really want to see inside!
    Inside are two separate B&O IcePower 500ASP modules, each rated at 250wpc into 8ohms and 550wpc into 4ohms.
    The back panel has two boards for input switching and volume attenuation. They advertise a true resistive ladder for the volume control, but all I see is a chip for volume control...maybe I'm missing something but that is a bit misleading if it only uses a chip for attenuation.
    Otherwise, nicely laid out. Nice quality parts on all the boards. Front panel only has the optical encoder dial, a few buttons and the display. It is connected to the back with a long ribbon cable that actually lets you move the panel completely off and to the rear without disconnecting.
    edited February 2022
    Musical fidelity kw hybrid preamp
    Should have kept mine, you don’t see Dodd gear for sale very often.
    Still a little **** with his attitude when I met him at RMAF, he had to have been having a bad day.
    R.I.P.
    Just pulled my Jeff Rowland Model 1 out of storage. I had it upgraded with the new front end boards a few years back. Still sounds great!!!
    KEF 207s / Coda Continuum / SST Thoebe II / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Ikeda 9C2 & Dynavector XX2 Mk II carts
    Sony CDP-650ESD always astounds me. 19 lbs of pleasure…
    Stan
    Main 2ch:
    HT:
    Other stuff:
    engie490 wrote: »
    Are those power supply fuses? Can't tell but if you're in the "better power cables sound better" group those should be upgraded. If you have any fuses in the output stage like that, they are sucking the life out an excellent amp!
    audioluvr wrote: »
    Good eye! Those are rail fuses...and they work well because they saved the amp from a naughty preamp!
    ^^^ I have no idea what that is?! :p I initially thought it was a TVC, but, nooooooo...
  • The photo was the underside of a switching panel that I built for my model train layout. I allows me to switch up to 20 turnouts and control the power to up to 20 different sections of the track. Here is a photo of the top and rear sections of the panel. The paint scheme is based upon the old Erie Lackawanna railroad colors.
    edited September 2022
    Outstanding!
    I am reminded of some manner of old folk (?) song my maternal grandfather used to "sing" (for lack of a better word)... something about "the Erie Lackawan'..."
    EDIT: Well... alrighty then... maybe it was Where Do You Work-a, John? ("On the Delaware Lackawan' ")... but maybe not. :p
    That said, I found this -- which ain't my grandfather's song... but it is quite cool (and a new find for me)! :)
    https://youtu.be/A2a_ruhWcj8
    I was a train controller a thousand lifetimes ago. For the Soo Line. I just found my stuff from train dispatcher school in Minneapolis, which I kept for some reason. Very hard school, way more complex than I remember.
    Luxman MQ-88uSE
    Great photos, all - who doesn't like stereo guts photos - but man this thread title is GNARLY.
    msg wrote: »
    blame the OP (and, of course, the Vanilla nanny censor) ;)
    let's see, do I have any guts I haven't spilled here yet?
    Lemme look...
    53439853597_0122374a2c_b.jpgDSC_0740 (2) by Mark Hardy, on Flickr
    Dump find Yamaha RX-570 with the top popped for its roughly every five year control cleaning. This one lives in our "den" hooked up (sort of) to a TV (sort of) that we almost never watch. :p
    One of my monoblocks wouldn't turn on... Sad but half way expected due to the age... Took an opportunity to take things apart and look for burnt things. I couldn't access it but I think the regenerator is the culprit
    msg wrote: »
    Careful Scott will be in love 💞💞💞
    DANGER PART! DANGER PART!
    B)
    msg wrote: »
    Agreed, it's way past time to change the thread title.
    Mark always had a ways with words
    Outstanding!
    rics to Erie Lackawanna
    Erie Lackawanna Video:
    THIS IS THE ROOM WHERE THEY WERE BORN
    ALL OF THE KIDS GROWN UP SO LONG NOW
    AND IF I'M QUIET I CAN HEAR THEM FIGHT
    BUT THE ONLY REAL SOUND IS THAT WHISTLING TRAIN AT NIGHT
    THAT'S THE ONLY THING THAT HAS STAYED THE SAME
    THE LONELY WHINE OF THE NEW YORK TRAIN
    USED TO HEAR IT COMING FOR ME IN DREAMS
    BUT NOW IT JUST SINGS ME TO SLEEP IT SEEMS
    I CAN HEAR A WRECKING BALL COMING FOR THE HOUSE
    SEE A WRECKING BALL GONNA TEAR IT DOWN
    IN THIS KITCHEN WE WOULD LAUGH AND SING
    NOW I EAT ALONE AT BURGER KING
    MY WIFE USED TO COME HOME AND COOK THE MEALS
    NOW MY DAUGHTER COMES WEEKLY TO FEED ME PILLS
    USED TO RUN THROUGH FIELDS TO PUT PENNIES ON THE TRACK
    NOW IT'S JUST BIG HOUSES WITH POOLS OUT BACK
    THEY'LL BULLDOZE THIS HOUSE WHEN I AM GONE
    AND NO-ONE WILL BE HERE TO SING THAT OLD TRAIN SONG
    New thread title...KUDOS!!!
Welcome!
Welcome!
