Second pair of SDA-2As
13»
  • Gardenstater
    Gardenstater Posts: 4,879
    edited November 2020
    This is some interesting info on speaker enclosure construction materials and methods: http://www.resfreq.com/usefulinfoonwood.html
    Here's another interesting article: https://manualzz.com/doc/32045707/panel-damping-studies--reducing-loudspeaker-enclosure-vib...
    Post edited by Gardenstater on
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,739
    Sorry for my vagueness, I programmed the RDO and SL2000 billet plates at 0.365" radius from center of mount hole to tweeter edge where it meets cabinet.
  • spongebobsquarepants
    Thanks! Ive been driving myself nuts with this. I had the radius and diameter mixed up (very new to this). I divided my 19mm measurement by 2 and came up with 9.5mm (.374) but it didn't seem quite right. I was holding a tweeter plate up to the monitor at one point. :D
    xschop Posts: 5,739
    I didn't post about it specifically in the Billet RD0 thread either, but the bezel edge also covers up any small imperfections from the factory cabinet router-ing (sic).
    The 0.365r. is a snug fit....No air leaks there.
    xschop Posts: 5,739
    I hit the like button already. Very nice.
  • Gardenstater
    Looks great so far! A biscuit joiner would probably be helpful for glue-up and assembly (or assembaly as ol' Norm A. used to say).
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    F1nut Posts: 52,294
    Biscuit joints suck.
    Pretty committed to dados, miters, and titebond 3 at this point. Went with the miters on the corners for looks, so theres no exposed layers of plywood. The miters should be pretty tight, they were cut with a 45 router bit on the cnc.
    Cant wait to put em together!
  • Gardenstater
    edited February 2021
    Even better! Locking miter or plain? I didn't see that in the picture although I think I see some dados on the side panels now that I look again.
    Be sure to account for glue soak when you do that, if plain miters. I think an initial coat brushed on and allowed to soak in after squeegee off excess will work well. Keep us posted!
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,739
    In classic Polk fashion, you could always add an extra half-gallon of poly glue and let it drip from every seam. :D
  • Gardenstater
    If you want to be perfectionist, and why not since you're building from scratch, you might reinforce everything with a fillet of thickened epoxy on the inside (like tongue depressor radius). I guess I'd want to calculate how that would affect the volumetric space percentage wise but I'd guess it is minimal.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    Got the bracing glued in nice and square! One more glue session and they’ll be complete!
    xschop Posts: 5,739
    Nice. The MW backing rings will fit no problem.
    Both cabinets are fully glued!
    Stopping by the shop tomorrow for some sanding and finishing.
    Also.... thanks @westmassguy for doing a great job with these crossovers! Running them in the stock cabinets now and really enjoying it!
    Before and after:
  • westmassguy
    westmassguy Posts: 6,850
    My pleasure John.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    pitdogg2 Posts: 27,766
    Man those look nice!!
    What kind of plywood?
    Thanks!
    I’m pretty sure it’s called B/BB 18mm Baltic Birch.
