Today's haul - after long break - SDA 1's
13»
  • Mystery
    Mystery Posts: 2,546
    Dude inside you should have numbers or HNG or something close to discern. Either way you're going to have two different color wires if the green wire is on + or #1 then green wire on other side needs to be on - or #2 then wire two would be the same.
    Yes you can let the magic smoke out if done wrong. But seriously it's not hard to figure out.
    So the IC pin connects to opposite color on the other speaker?
    I'll pull the crossover out and check when I get some time.
    I'm thinking of just soldering the wires on the pins and making a connect disconnect jig/switch in the middle somewhere.
    Too many things to do... ;)
    F1nut Posts: 51,930
    Oh lawd
  • Let "green" = unknown wire.
    Harry / Marietta GA
  • Gardenstater
    Gardenstater Posts: 4,797
    Mystery wrote: »
    If you do it the way I suggested above with meter checks to determine which pin is #1 or #2, you don't have to open up anything or care a lick what the wire color is.....just sayin' :)
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    pitdogg2 Posts: 27,208
    Is it my cajun coming through?
  • Mystery
    Okay right now they are setup as regular speakers.
    I moved the dimensional woofers from both to left speakers mid woofers.
    Now both speakers are working except of course both dimensional mids are bad.
    How critical is matching the dimensional mid?
    It's not getting full signal all the time like regular woofers.
    Can I use mid other Polk speakers?
    edited January 2021
  • Mystery
    After looking at all the speakers I have, some way better as is from factory, I've decided to pass these on rather than investing time and money just to make them work.
    Even then, it'll be whole another ordeal to upgrade plus the huge size.
    I'll list these locally to see if I get any bite before parting them out.
    Thanks for all your comments and suggestions.
