This one kinda looks like Polk RTA-12's...
Has anyone heard these?
Peerless tweeter on the top just like RTA-12's.
Design Acoustics D-2.
  • boston1450
    boston1450 Posts: 7,473
    edited January 2021
    Strange how the tweets aim at the moon.
    Randy/Maine
  • Mystery
    Mystery Posts: 2,546
    edited January 2021
    boston1450 wrote: »
    Looks like that was done to flatten the tweeter response curve.
    The Peerless dome tweeter was set at an angle as frequency response graphs showed that the 45 degree off axis response curves were the flattest and smoothest. Those tweeters can be a bit "sizzly" directly on axis, which you can hear if you stand in front of the speaker.
  • aprazer402
    aprazer402 Posts: 3,097
    edited January 2021
    I'm familiar with, but have not personally owned Design Acoustic's D-12 dodecahedron and the D-6. Their D-2, D-3 and D-4a models are fairly rare. I had to look up the size on these D-2's; $150.00 MSRP, 34" high, 12.25" square, 35 lbs. The tweeter is 30 degrees to vertical. The rocker switch next to the tweeter reduces the tweeter output by 3db for overly bright rooms. 10" woofer. The reviews were good.
  • Mystery
    aprazer402 wrote: »
    ... these D-2's; $150.00 MSRP, 34" high, 12.25" square, 35 lbs. The tweeter is 30 degrees to vertical...
    That is pretty cheap msrp for floor standing speakers.
    Polk 5jr bookshelf speakers are more.
  • Gardenstater
    Gardenstater Posts: 4,188
    That's very odd and interesting. I'd like to do a search for reviews and will. The Peerless data sheet doesn't show off axis response to be flatter however:
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • skrol
    skrol Posts: 3,340
    So the old Monitor stands had about a 6 deg tilt. I believe this was done for for time alignment. If they were ear level, that tilt might tame them a little. However, since they were well below the ear the tilt would tend to aim them up at the ear and be more on-axis. ... just thinking out loud.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Gardenstater
    edited January 2021
    Stereo Review, July 1976, p. 42
    https://worldradiohistory.com/Archive-All-Audio/Archive-HiFI-Stereo/70s/HiFi-Stereo-Review-1976-07.pdf
    It explains the tweeter angle better. Horizontal dispersion; everywhere in the horizontal plane, is more uniform when tweeter is tilted up by 60deg.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    audioluvr Posts: 5,438
    Those specs were taken while mounted on a vertical surface. Could be totally different different horizontally.
    Clearly they were not a big seller even at the bargain basement MSRP.
  • Gardenstater
    edited January 2021
    audioluvr wrote: »
    Those specs were taken horizontally while the tweeter was mounted on a vertical surface. Could be totally different different horizontally when the tweeter is tipped back by 60deg.
    Forgive me for the edit. I thought it was clearer this way. :)
    Not that expensive for sure but I think the price was $150 per speaker. I paid $175 ea. for my 7B's.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
