Ronxs Candle Electric Lighter reduces static noise on vinyl
[Deleted User]
[Deleted User] Posts: 7,658
edited December 2020 in 2 Channel Audio
For those of you who have or remember the Zerostat anti-static gun will already have an idea what this inexpensive device can accomplish to improve the way records can sound. All you need to do is have the record rotating, push the slider switch to the "on" position and push a small button and wave the tip of the lighter back and forth across the surface of the record at about 1/2".
The results are very impressive, less "touch down" noise as the stylus finds the lead in groove and a marked reduction in noise throughout the complete record. Try it you'll like it!
    msg Posts: 9,476
    What?!? No way, really? So, the lighter is lit and you wave it back and forth over the record from outer to inner and back again a few times?
    That Zerostat is a pain to use properly. No clicks takes some real practice and patience.
  • [Deleted User]
    I should have been clearer, there's not a flame, it's like a spark plug discharge. A very small blue arc between the two pole pieces that's releasing ions which cancel static on the record. Couldn't be easier to use, it's the opposite of most audiophile gizmos, it's cheap and easy to use.
    msg Posts: 9,476
    Ohhhhh. So do you hold the button and it keeps the arc going until you let go?
    Like this?
    https://www.amazon.com/RONXS-Lighter-Upgraded-Flexible-Fireworks/dp/B07WR9ZX8V
    pitdogg2 Posts: 24,611
    Nice I remember and used the Zerostat.
  • [Deleted User]
    Yes, that's correct. Couldn't be easier.
  • BlueMDPicker
    I still use my 40+ year old Zerostat. It's survived solely due to only my hand ever being on it I believe.
  • jdjohn
    jdjohn Posts: 3,007
    Good timing with the cold dry air this time of year. Tis the season!
  • ken brydson
    ken brydson Posts: 8,654
    Nope, too easy.....
    mhardy6647 Posts: 33,068
    Since this lighter thing uses a plasma (apparently) -- add a little transformer and a couple of wires and voila*, a low moving mass tweeter (albeit a low sensitivity tweeter)
    http://www.plasmatweeter.de/eng_plasma.htm
    I do have to say -- with trepidation** 'cause I am a biochemist and not a physicist -- I don't see how a plasma generator deionizes anything. Plasmas are electrically neutral AFAIK; essentially a "gas" made of positive and negative ions.
    _____________
    * or viola, if you prefer.
    ** as opposed to trepanation.
  • afterburnt
    afterburnt Posts: 7,892
    I use this, it's cheap and reduces fire danger.
    msg Posts: 9,476
    Looks like some dried hair on there? Seen lots of practical use it seems.
    This was the first tool of my dad's that I would break, nailing some 2x4s onto a tree. It's a bit disconcerting when you're hammering away, and then draw back to feel the head go flying off somewhere, while you stand there staring at the spiky top of a broken handle for a second before you realize you don't know where the metal thing is going to land.
  • [Deleted User]
    I sent one of these electric lighters as a New Year's gift to my best friend who is a dedicated audiophile with a good ear and not easily impressed. He called me tonight and was amazed at what a difference it made. He just couldn't believe how quiet and clear everything sounded.
  • agfrost
    agfrost Posts: 2,421
    15% coupon (click the checkbox!) on the black one at the link above. I went ahead and ordered one.
    Jay
  • DaveHo
    DaveHo Posts: 3,481
    I ordered one as well. I have a zerostat, but frankly am not convinced it works all that great. For under $20, why not!
  • [Deleted User]
    The idea is to have the record turning and with the lighter about 1/2" above record surface move it in an arc from label edge to beginning groove a couple of times. I hope you find it works. I've read positive reviews on other audio forums.
    heh... antistatic... positive reviews.
    I see what you did there.
    B)
  • jdjohn
    jdjohn Posts: 3,007
    ^^^Bunch of hacks on that site :p
    I think I am gonna buy one of these things...
  • afterburnt
    I got one but I ain't done tested it yet, still no seating in my vinyl room. If it dern't work I still need it for my bbq and outdoor range.
  • jdjohn
    jdjohn Posts: 3,007
    afterburnt wrote: »
    Don't forget about scented candles.
  • Milito
    Milito Posts: 1,915
    Just ordered one.
    Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables.
  • [Deleted User]
    You could always wait for the audiophile "higgs boson, quantum entangled" version?
    edited January 2021
    afterburnt wrote: »
    Do you need to sit down to use it?
    ahem.
    That is a good point -- it can always be used for, you know, lighting fires.
    That may help me rationalize the purchase to Mrs. H. :|
    Yeah, but the problem with that is that, whenever I would de-stat a rekkid, someone else's rekkid would have its clicks & pops reduced. Maybe even somewhen else.
    PS Note my careful choice of the subjunctive mood in that last paragraph.
    PPS How the heck does one pronounce "RONXS", anyway? How many syllables? Is it the plural of RONX?
    B)
  • [Deleted User]
    edited January 2021
    Dave van Ronxs and the Hudson Dusters.
    edited January 2021
    Dave von Ronxs and the Hudson Dusters.
    Get into a bust up at the Lazy J Saloon
    The R and X are silent 😉
    https://youtu.be/UpbNdTY0ogQ
    The R and X are silent 😉[/quote]
    Are you sure it's not the "N" that's silent?
  • afterburnt
    afterburnt wrote: »
    ahem.
    I am almost too lazy to play vinyl, I am definitely too lazy to stand there and listen to it. I ordered a couch on 10-23-20 and still haven't seen it.
    I am empathetic re: spinnin' vinyls. B)
    I've gotten like that myself.
    I got a nice new-to-us sofa for my hifi room last year -- it won't fit up the stairs, so it is in our "den" until I get up the gumption to use a tractor's bucket to lift it up to the center window upstairs and bring it in that way.
    Meanwhile, I have our son's erstwhile futon upstairs, including its rather bold :p striped cover.
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    Maybe this guy had something to do with it?
