Belles 21a preamp
24
  • dr1978
    dr1978 Posts: 424
    marvda1 wrote: »
    @dr1978 open that puppy up. here is an internal pic with auricaps. i recall david belles saying you don't have to replace that fifth cap up front.903resltswlh.jpg
    I emailed Dave at Power Modules to see if that serial number label indicated that they did the upgrade. Indeed it does. But I'll definitely open it up as soon as I get it.
    Pro-ject 2 Experience SB, OPPO BDP-103, Marantz SR5011, Lounge LCR MKIII, McCormack DNA-HT5, Polk LSiM705, Polk LSiM706C, Polk LSiM702, SVS SB16-Ultra
    audioluvr Posts: 5,992
    Dave's kind of a slow responder. Probably one of those eccentric genius idiosyncrasies. Looks legit though.
  • dr1978
    dr1978 Posts: 424
    @marvda1 crazy, guess what the throw in tubes are...
  • dr1978
    dr1978 Posts: 424
    edited January 2021
    Unfortunately I can't get the sucker open! The screws on the side are ridiculously small. I had a tool for the ones on the faceplate, but I'm at a standstill with the others.
  • dr1978
    dr1978 Posts: 424
    Does this look like a homemade power cord?
  • marvda1
    marvda1 Posts: 4,963
    dr1978 wrote: »
    mullards?????
    Puritan PSM156
  • dr1978
    dr1978 Posts: 424
    From my other thread..
    marvda1 wrote: »
    @dr1978 make sure you use good quiet tubes in the belles.
    here's one you can try while it's cheap.
    https://upscaleaudio.com/collections/preamp-tubes/products/ge-12au7-6189w
    i bought a pair of radiotechnique 6189w when they were $60 ea. now they are $95 ea.
  • dr1978
    dr1978 Posts: 424
    Haha, whoops. I thought that link was for the radiotechnique 6189w. That's actually what he sent. Do you know how I can tell what grade they are?
    Sorry, my posting is a mess tonight, too much excitement!
  • marvda1
    not sure but if you have the box with the upscale audio label on it see if it is graded noise-A and microphonics-A
    Puritan PSM156
  • dr1978
    dr1978 Posts: 424
    Sure is. No clue what it signifies, but I see that the T2 values of each don't match.
    pitdogg2 Posts: 27,372
    dr1978 wrote: »
    The triode difference is not unusual.
    The allen wrench for the side screws is really small.
  • dr1978
    dr1978 Posts: 424
    Do you happen to know what size it takes? Or did your unit come with it? I have a decent multi-tool, but the smallest isn't quite small enough.
    I'll check. I'd run it as is for a baseline.. Could be what's in it are really good tubes.
  • dr1978
    dr1978 Posts: 424
    For sure, I'm not planning on swapping them out for a while, just curious.
  • marvda1
    Let's get to the important part, "Da Sound Boss, Da Sound" :D
    Puritan PSM156
  • dr1978
    dr1978 Posts: 424
    Ha, ok ok. I didn't get to devote much time last night, but there were some moments that immediately stood out. Specifically on songs with rich vocals or a lot of atmosphere...those elements were magnified and had me feeling like I was swimming in them. Codex by Radiohead was probably the highlight. One of my least favorite songs on their The King of Limbs album, but I was entranced last night.
    Definitely can't wait to do a ton more listening to find some less obvious attributes. Those that lobbied for a tube pre in my upgrade thread were of course on the money. I couldn't be happier with how everything turned out though.
  • marvda1
    also pay attention to the bass.
    Puritan PSM156
  • dr1978
    dr1978 Posts: 424
    edited January 2021
    I'll do that, and I'm glad you brought up bass. I really enjoyed listening to my 705's in full band for once, and didn't find anything lacking, but I was wondering if there was a way to integrate a sub with the 21a. I've got the HT Bypass hooked up and working, but I wasn't sure if I could turn this into a 2.1 setup for music.
    Sorry for the delay. Side tracked. Those small screws take a 3/32" allen wrench.
  • dr1978
    dr1978 Posts: 424
    audioluvr wrote: »
    Thanks a ton, I'll have to head out and get one.
  • dr1978
    dr1978 Posts: 424
    edited January 2021
    Any drawbacks to connecting the balanced output from the Belles to the balance input of my svs? Seems like that might do the trick. I'm using the unbalanced connections for pre to power amp and Marantz to svs.
    Some gear will only do one or the other.
  • marvda1
    edited January 2021
    ok the 21a is not truly balanced, so if the svs is truly balanced i don't know how hooking one to the other works.
    Puritan PSM156
  • dr1978
    dr1978 Posts: 424
    From the Soundstage review...
    "the 21A's circuitry is not fully balanced, however"
  • dr1978
    dr1978 Posts: 424
    Mullards?
  • dr1978
    dr1978 Posts: 424
    Here's the whole thing..
    edited January 2021
    I think that's a 12AT7 which is the wrong one.
    Edit: Brimar 12au7
    https://reverb.com/item/33830323-nos-brimar-ecc82-12au7-pair
    dr1978 wrote: »
    Mullards?
    audioluvr wrote: »
    dr1978 wrote: »
    Mullards?
    CV4003 is the designated number for the civilian valve known as 12au7.
    If you want to know the maker we'll need many more pictures on structure and or any other markings. Could it be Mullard .. yes Could it be another foreign manufacturer that copies those markings ...yes
    Mullards were made in Great Britain and also other european countries that mullard contracted out to. Before Mullard went to Russia they had also been made by a company in Japan.
    True Mullards not sure.
  • dr1978
    dr1978 Posts: 424
    Thank you sir. I already closed it back up, when I get the itch to try the radiotechnique's I'll take some more pictures.
