Looking for Misc Audio Deals of the Day? Updated info here!
LS90s - $200, no affiliation.
https://newyork.craigslist.org/que/ele/d/forest-hills-polk-audio-ls90-speakers/7250387979.html
Pair of WW Silver Eclipse XLR's for sale on USAM. These don't come up very often. If you have the ability to connect your pre and amp(s) with balanced cables these are REALLY good. In no way accentuated or overpower certain frequencies but simply make everything better from deep bass to the upper most registers.
https://www.usaudiomart.com/details/649673244-used-wireworld-silver-eclipse-7-xlr-balanced-interconnects-1-meter-pair-002/
Have not seen any of these advertised in quite a while:
Infinity Modulus Speakers & Subwoofer - $300 (Buford/Dacula)
https://atlanta.craigslist.org/nat/ele/d/buford-infinity-modulus-speakers/7252571019.html"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA -
Aragon Palladium II Monoblocks in Wisconsin.
If I was in the area I’d grab them yesterday.
https://madison.craigslist.org/ele/d/madison-aragon-palladiums/7254792266.html -
@pitdogg2"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Yea I wish. I do not think its a large enough jump from my 8008bb. Very nice none the less. I'm not sure are those Mondial or Klipsch design?
Mondial designed. The originals and MkII were under Mondial. Even the Palladium 1K which were released once acquired by Klipsch were still the same Mondial designed amp but just with new outer case work that the Klipsch people wanted. If it had the 8008 or Palladium name, it was Mondial work...Klipsch started with new number sequences under the Aragon name and they were never in the same ballpark as the original designs.
I’ve always been on the lookout for a pair but never show up close enough or at a reasonable price. They claim I think, 85watts class A but I’m not sure that is 100 percent true. Either way the palladium’s run further into class A than the 8008 models with about twice as much power overall I believe. -
Go get them P-dog...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
They are very nice here is what I found on them.
The implementation of Class A outputs eliminates any possiblity of crossover notch distortion. The high bias required for Class A operation provides for the bipolar output transistors to operate without switching within the monoblock Palladium's 125 watt Class A power rating. Power is supplied to the circuits by a specially wound 2000VA transformer.
I bought my 8008bb from a guy in Tennessee for 1300.00. I've see them go for up to 1600+. Mine was tested and 8ohm bench test was in excess 300wpc 4ohm was 450wpc. The gentleman I bought it from was an engineer for Emotiva in Franklin Tennessee.
Here he is with my amp being tested to assure me it was in perfect condition.
I've had it since about March, it replaced the 4004mk2 I bought from Keith. I'm totally liking the articulation these amps have. These amps are old enough they're due shortly for a recap and gone through.nooshinjohn wrote: »Go get them P-dog...
Loan me a frogskin or 1500... 😉 -
They really are great amps. I had the 8008 mkii...Mondial design with Klipsch cosmetics that I purchased from a fellow member here. One of the couple amps I should have kept. It seemed to have never ending power.
You could always shake your money maker for Tonyb...
San Jose California area...
325.00 for the pr..
https://www.ebay.com/itm/Audiophile-Amplifier-Speaker-Stands-Black-Walnut-With-Adj-Isolation-Feet-AMP/303814978742?_trkparms=aid=1110009&algo=SPLICE.COMPLISTINGS&ao=1&asc=20200220094952&meid=3810e3e977874ad29bd5b50f16db4ca9&pid=100008&rk=1&rkt=12&sd=265002807504&itm=303814978742&pmt=1&noa=0&pg=2047675&algv=default&brand=Unbranded&_trksid=p2047675.c100008.m2219
Those are very nice looking.
I agree...they are right purdy."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
A couple of Acoustic Research tube preamps:
LS15 for $1,400:
https://nashville.craigslist.org/ele/d/murfreesboro-audio-research-ls-15-line/7257600584.html
I've dealt with this guy before, and he will do it right.
LS2 for $900:
https://nashville.craigslist.org/ele/d/thompsons-station-revised-stereophile/7239022679.html
I've also dealt with this Korean gentleman, and his gear is legit."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Indeed I did."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
OPPO DV-980H Super Audio, DVD/CD player
Works perfectly. Comes with original remote.
$40
Listed a week ago in Columbus, OH
https://www.facebook.com/marketplace/item/752810268968082/?ref=browse_tab&referral_code=undefined -
Polk Legend L400 center channel - $950 or Best Offer over on AVSForum.
https://www.avsforum.com/threads/fs-polk-audio-legend-l400-center-channel-speaker-mint-condition.3177952/2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
Polk Audio Center LSiM706c
$200
Listed 2 days ago in Greenwood, IN
https://www.facebook.com/marketplace/item/164199651740295/?ref=search&referral_code=undefined -
$200
How dare you tempt me with forbidden fruit....."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
$200
Steal of a deal... -
Wish I knew someone in Indiana..
Wonder how this would mesh up with RT55i? -
Bud could use some surrounds...
Pioneer Elite SC-72
$250 (price drop)
Front of unit is filthy. I'm amazed the person wouldn't take the time to clean it before taking a picture.
Listed 4 weeks ago in Athens, TN
https://www.facebook.com/marketplace/item/238798394337105/?ref=browse_tab&referral_code=undefined -
Right!, and you're close. It's 2.5 hrs away for me. Has me thinking about LSiM again.... but I have my eye on something else... so I must resist.EndersShadow wrote: »Polk Audio Center LSiM706c
$200
Anyway, here are some other new in box LSiM listings in Alabama that I ran across on FB Marketplace. The owner told me that they purchased to install in a home they planned to build but plans changed due to the death of her husband. So she's trying to clear this stuff out and is open to offers. I guess she purchased a couple of years ago before all of the the deals last year and knows she's taking a major loss given the buyers market on LSiM these days. She stated that she is even open to donating to a charity if she can't sell for a reasonable amount, so.... I'm posting here to help her out. No affiliation.
3 x LSiM706c
https://www.facebook.com/marketplace/item/868562300584865/?ref=product_details&referral_code=undefined
1 x LSiM702 f/x
https://www.facebook.com/groups/429424627133707/permalink/3524665284276277/
1 x Atrium SAT30 & SUB10 Outdoor Garden speaker set
https://www.facebook.com/marketplace/item/1539886553066253/?ref=product_details&referral_code=undefined
1 x DSW Pro 600 sub
https://www.facebook.com/groups/429424627133707/permalink/3524644817611657/
Post edited by WLDock on2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
Great prices but damn Walt that's a terrible story.
Yeah, I felt bad for her. Then, I was trying to sort through how they ended up with three 706 centers. I assumed they purchased a bulk crate of goods or something but that was not the case. Maybe they thought they were LCR capable for HT?Great prices but damn Walt that's a terrible story.2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
