Benchmark LA4 preamp and AHB2 power amplifier review
I like the small footprint. Is that shelf standard rack width? Cool that both fit on the same shelf."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Congrats!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
The shelf is 23" wide. -
Does the LA4 really do nothing at all to the sound?
It does do something to the sound, it controls the volume. -
The LA4 & AHB2 combo sounds perfect. I love it.
Because neither component imparts any of its own sonic character, the XLR interconnect cable between the preamp and amp becomes even more noticeable.
I've tried two different XLR pairs so far, and it was effortless to hear the difference between them. Each had a very different presentation.
I look forward to trying different 0.5m XLR cables here, to determine what sounds "best" to my ears. -
Other interesting observations and things that I like:
They're ready to go as soon as you turn them on, no perceptible warm-up time before they are at maximum performance.
The AHB2 gets only slightly warm to the touch during use, the LA4 hardly feels like it's above room temp.
No mechanical noise whatsoever from the units, nor any hiss through the tweeters.
And lastly, they put my name on the front panel, twice! How cool is that?!
Talk about Personal TouchSDA SRS 3.1TL's/SDA CRS+4.1TL's and some other stuff
The best way to describe the sound would be that it simply lets me hear more. I can now fully appreciate my source components, because I know that their S/N ratio isn't being limited by the preamp or amplifier.
Both my Vega G1 and SA-KI Ruby are sounding absolutely fantastic today.
Not sure what else to say, other than I love this Benchmark AHB2 and LA4 pairing. I wish all of my fellow audiophiles could hear its performance in their own systems. -
I'll PM you my shipping address 🤪Gustard X26 Pro DACBelles 21A Pre modded with Mundorf Supreme capsB&K M200 Sonata monoblocks refreshed and upgradedPolk SDA 1C's modded / 1000Va DreadnaughtWireworld Silver Eclipse IC's and speaker cablesHarman Kardon T65C w/Grado Gold. (Don't laugh. It sounds great!)There is about a 5% genetic difference between apes and men …but that difference is the difference between throwing your own poo when you are annoyed …and Einstein, Shakespeare and Miss January. by Dr. Sardonicus -
I was thinking it would be cool if there was an official Benchmark-sponsored forum demo program with the AHB2 and LA4 pairing.
Like we've had in the past with the MIT speaker & interconnect cables, Backert Labs preamp, Polk Legend L200 speakers, etc. -
I would need to demo 2 of them with my 80db sensitivity speakers.
I had to put a hat on my LA4 if I wanted to be able to play vinyl:
It's the Channel Islands Audio PEQ-1 MKII phono preamp. I'm using the Ortofon OM-30 cartridge which has a recommended capacitance of 200-500pf. I can set the PEQ-1 to either 100pf, 270pf, or 370pf or capacitance.
I tried it with it set to 100pf and the high frequencies seemed a little muffled/laid back/rolled off. I then switched it to 270pf and the highs were back and crisp, without sounding bright. I might try the 370pf setting later just to see what it sounds like, but for now will likely stick with 270pf. Here's how it's set currently:
All-things-phono-expert Jody @jdjohn what say you?
So, I'm not currently using the optional AC-15 upgraded linear power supply that I have which goes along with this, just the standard wall-wart style adapter that was included. I already didn't want to have to stack the phono pre itself like this, but I literally don't have any other way/room to make it work.
I checked the manual for the LA4 and it states the following: "The LA4does not emit strong magnetic fields and for this reason, it will not create interference with audio devices that are placed above or below the LA4."
In the manual for the AHB2, it states: "The AHB2 is magnetically shielded, and will not interfere with sensitive equipment mounted above or below theAHB2."
But for some reason I'm still hesitant to put the AC-15 power supply on top of it, knowing that it has a toroidal transformer inside.
Was actually considering one of these because I could actually put it under my turntable thanks to how thin it is, and then I wouldn't have to have anything stacked on either the amp or the preamp: https://www.musicdirect.com/phono-preamps/iFi-Micro-iPhono-3-MMMC-Phono-Preamplifier-Black-Label-Edition
My personal inquisition is: How does the LA4 compare to the DAC3/HGC? The latter does have two analog inputs. The LA4 clearly has a larger footprint, but no incorporated DAC, so I'm curious about comparisons between the two units."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
I had the iphono 2 a few years ago. Great sound for the money, but they have a documented history of power failures after a year or two. I don't think the 3 has been out long enough to be time tested yet, but it was frequent enough that I was relieved I moved on before having an issue. I'd be hesitant with the 3 because of that.Analog: MoFi MasterTracker > MoFi UltraDeck > Sutherland 20/20
MastersounD Dueventi > Rosso Fiorentino Certaldo or Arcam rHead > Hifiman HE4XX
Discogs -
Was actually considering one of these because I could actually put it under my turntable thanks to how thin it is, and then I wouldn't have to have anything stacked on either the amp or the preamp: https://www.musicdirect.com/phono-preamps/iFi-Micro-iPhono-3-MMMC-Phono-Preamplifier-Black-Label-Edition"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
I agree that normally something's physical size alone shouldn't be the determining factor, but the iFi is really one of the only options unless I want to stack one on top of my pre or amp. There's not too many thin phono preamps that are also "good".My personal inquisition is: How does the LA4 compare to the DAC3/HGC? The latter does have two analog inputs. The LA4 clearly has a larger footprint, but no incorporated DAC, so I'm curious about comparisons between the two units.
You'd have to ask Benchmark to be sure, but I think I recall reading somewhere that the LA4 is superior in several ways. I'm sure Rory at Benchmark would be happy to expand on what makes the preamp section of the LA4 different than that of the DAC3 HGC. I can give you his email address if you'd like. -
displayname wrote: »I had the iphono 2 a few years ago. Great sound for the money, but they have a documented history of power failures after a year or two. I don't think the 3 has been out long enough to be time tested yet, but it was frequent enough that I was relieved I moved on before having an issue. I'd be hesitant with the 3 because of that.
Was it the plug in power adapter that failed, or the power supply section inside the unit itself? -
Something inside the unit, can’t remember the exact details. I believe the most comprehensive thread is over on the Hoffman forums, but it was discussed on a few sites.Analog: MoFi MasterTracker > MoFi UltraDeck > Sutherland 20/20
Discogs -
Well hopefully they fixed it with the latest version! I don't like that all of iFi's products only have a 1 year warranty. Just seems chintzy.
Happy to see your review on the Benchmark site. I really like your writing style.
I want a DAC3/HGC - been reading about them for a few months. Jody I didn't know you had one until today.When we Forgive, the Past never controls us, and You live in Freedom
Harry / Marietta GA -
Harry, the DAC3/HGC is not much to look at, but man it sounds good. I really like the incorporated DAC, and the headphone outputs are also an important feature for me personally."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Since I greatly preferred the AQ Red River XLRs between my LA4 and AHB2, I decided to order the AQ Yukon XLRs to try for this connection.
I ordered both a 0.5m pair and 1m pair so I can try them between preamp and amp, as well as with G1 to preamp.
Differences between Red River and Yukon:
Red River:
Solid Perfect-Surface Copper (PSC) Conductors
Nitrogen-Injected Hard-Cell Foam Insulation
Metal-Layer Noise-Dissipation System (NDS)
Triple-Balanced Geometry
Cold-Welded Gold-Plated Plugs
Yukon:
Solid Perfect-Surface Copper+ (PSC+) Conductors
Polyethylene Air-Tube Insulation
Carbon-Based 3-Layer Noise-Dissipation System (NDS)
Cold-Welded Hanging-Silver Directly Over Pure Purple Copper Plugs
Main differences appear to be quality of the copper conductors, dialectic material, and connector metal plating. -
I got some AudioQuest Mackenzie XLR's I run from my DAC1 to my Music Hall a70.2 integrated amplifier last month.
I was running Big Sur RCA's before I got these. They aren't fully broken in yet, but they opened up the highs compared to the Big Sur cables and just an overall better more open sound.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. -
This actually answers my question. Thanks.
I'll stay focused on a phono pre.
At this point I'm sure I just sound like a raving lunatic who's talking to himself, but I am beyond thrilled with the performance of the Benchmark LA4 and AHB2 combo.
It feels incredible to know that for my personal tastes, these two components tick all my boxes. I have found my reference. I will never sell them.
Their detail retrieval is simply stunning. They let me hear everything. Having a power amplifier with a better S/N ratio than many preamps and DACs is the key.
I am continually astounded by the uncanny sensation of being able to hear every single sound contained within my favorite music. It is a luxury which I do not take for granted. -
Happy for you Drew, I knew when you first reviewed this combo, they would be in your future. Congrats on reaching Nirvana
SDA SRS 3.1TL's/SDA CRS+4.1TL's and some other stuff -
Pretty awesome that it's such a great combo.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streamer: Roon ROCK on wifi'd NUC & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
You can donate the Norma to me and I'll put it away as a backupAmplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Speaker Cables: Organic Audio Organic Reference 2
Interconnects: Argento Organic Reference 2, Argento Organic 2
Power Cables by: Argento Organic Reference, Synergistic Research Foundation 10 and 12 ga.
Wireworld Spaceport -
Say what?!
