Looking for Misc Audio Deals of the Day? Updated info here!
I know nothing about these, whether it's a deal, just a so-so price, or 'you're out of your mind asking that kind of money'... Just a cool looking vintage set of speakers:
https://pennstate.craigslist.org/ele/d/state-college-sansui-sp-x7000-speakers/7250915535.html
My neighbor had these along with a Sansui stereo receiver Was my 1st introduction to decent stereo sound back in the 70's.Yep, my name really is Bob.
Rogue Audio Conus Magnum iii Dark, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
The cabinets on the vintage Sansui speakers are amazing and they sound pretty good too. They don’t seem to command high prices though. I have seen them on CL for $100 -$150.
One of my roommates in college had a full blown Sansui system he got overseas when he was in Nam and left for the states. He said he spent $2,500 on it and this was in the early seventies.
That was my introduction to a nice system. I hated it when he moved out.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream -
That was a relatively common speaker design back then. My first decent speakers were the Pioneer CS-A700 I bought in 72.
Three 20 amp circuits. -
LS90s - $200, no affiliation.
https://newyork.craigslist.org/que/ele/d/forest-hills-polk-audio-ls90-speakers/7250387979.html
Pair of WW Silver Eclipse XLR's for sale on USAM. These don't come up very often. If you have the ability to connect your pre and amp(s) with balanced cables these are REALLY good. In no way accentuated or overpower certain frequencies but simply make everything better from deep bass to the upper most registers.
https://www.usaudiomart.com/details/649673244-used-wireworld-silver-eclipse-7-xlr-balanced-interconnects-1-meter-pair-002/
Have not seen any of these advertised in quite a while:
Infinity Modulus Speakers & Subwoofer - $300 (Buford/Dacula)
https://atlanta.craigslist.org/nat/ele/d/buford-infinity-modulus-speakers/7252571019.html"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Aragon Palladium II Monoblocks in Wisconsin.
If I was in the area I’d grab them yesterday.
https://madison.craigslist.org/ele/d/madison-aragon-palladiums/7254792266.html -
@pitdogg2"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Yea I wish. I do not think its a large enough jump from my 8008bb. Very nice none the less. I'm not sure are those Mondial or Klipsch design?
Mondial designed. The originals and MkII were under Mondial. Even the Palladium 1K which were released once acquired by Klipsch were still the same Mondial designed amp but just with new outer case work that the Klipsch people wanted. If it had the 8008 or Palladium name, it was Mondial work...Klipsch started with new number sequences under the Aragon name and they were never in the same ballpark as the original designs.
I’ve always been on the lookout for a pair but never show up close enough or at a reasonable price. They claim I think, 85watts class A but I’m not sure that is 100 percent true. Either way the palladium’s run further into class A than the 8008 models with about twice as much power overall I believe. -
Go get them P-dog...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
They are very nice here is what I found on them.
The implementation of Class A outputs eliminates any possiblity of crossover notch distortion. The high bias required for Class A operation provides for the bipolar output transistors to operate without switching within the monoblock Palladium's 125 watt Class A power rating. Power is supplied to the circuits by a specially wound 2000VA transformer.
I bought my 8008bb from a guy in Tennessee for 1300.00. I've see them go for up to 1600+. Mine was tested and 8ohm bench test was in excess 300wpc 4ohm was 450wpc. The gentleman I bought it from was an engineer for Emotiva in Franklin Tennessee.
Here he is with my amp being tested to assure me it was in perfect condition.
I've had it since about March, it replaced the 4004mk2 I bought from Keith. I'm totally liking the articulation these amps have. These amps are old enough they're due shortly for a recap and gone through.nooshinjohn wrote: »Go get them P-dog...
Loan me a frogskin or 1500... 😉 -
They really are great amps. I had the 8008 mkii...Mondial design with Klipsch cosmetics that I purchased from a fellow member here. One of the couple amps I should have kept. It seemed to have never ending power.
You could always shake your money maker for Tonyb...
San Jose California area...
325.00 for the pr..
https://www.ebay.com/itm/Audiophile-Amplifier-Speaker-Stands-Black-Walnut-With-Adj-Isolation-Feet-AMP/303814978742?_trkparms=aid=1110009&algo=SPLICE.COMPLISTINGS&ao=1&asc=20200220094952&meid=3810e3e977874ad29bd5b50f16db4ca9&pid=100008&rk=1&rkt=12&sd=265002807504&itm=303814978742&pmt=1&noa=0&pg=2047675&algv=default&brand=Unbranded&_trksid=p2047675.c100008.m2219
Those are very nice looking.
I agree...they are right purdy."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
A couple of Acoustic Research tube preamps:
LS15 for $1,400:
https://nashville.craigslist.org/ele/d/murfreesboro-audio-research-ls-15-line/7257600584.html
I've dealt with this guy before, and he will do it right.
LS2 for $900:
https://nashville.craigslist.org/ele/d/thompsons-station-revised-stereophile/7239022679.html
I've also dealt with this Korean gentleman, and his gear is legit."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Indeed I did."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
OPPO DV-980H Super Audio, DVD/CD player
Works perfectly. Comes with original remote.
$40
Listed a week ago in Columbus, OH
https://www.facebook.com/marketplace/item/752810268968082/?ref=browse_tab&referral_code=undefined -
Polk Legend L400 center channel - $950 or Best Offer over on AVSForum.
https://www.avsforum.com/threads/fs-polk-audio-legend-l400-center-channel-speaker-mint-condition.3177952/2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
5.2 A/V Setup | OLED TV - Sony Bravia XR A80J 77" | Source - Fire TV 4K Max, Wiim Pro | AVR - Anthem MRX 520 | Integrated - Musical Fidelity A5 | Speakers: Main - Boston Acoustics VS 336 | Center - Boston Acoustics VS 325c | Rear - Boston Acoustics VR-MX | Sub 1 - Boston Acoustics VPS 210 | Sub 2 - HSU VTF-2 mk3 -
Polk Audio Center LSiM706c
$200
Listed 2 days ago in Greenwood, IN
https://www.facebook.com/marketplace/item/164199651740295/?ref=search&referral_code=undefined -
$200
How dare you tempt me with forbidden fruit....."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
$200
Steal of a deal... -
Wish I knew someone in Indiana..
Wonder how this would mesh up with RT55i? -
