Help
I’ve had the command sound bar for a month now & the Remote will not work. Any ideas on how i can I set the remote
  • karlmears
    Any answers yet. I have same problem
    F1nut Posts: 52,301
    Did you pull the protective membrane off the battery?
  • marishaw21
    Same issue here. Worked fine for a few months (straight from the packaging) then it just stopped. Several types of brand new replacement batteries and nothing.
  • SeleniumFalcon
    It would be best to contact Polk's CS at: 1-800-377-7655 they can help.
