Help
Gleezy19
I’ve had the command sound bar for a month now & the Remote will not work. Any ideas on how i can I set the remote
Did you pull the protective membrane off the battery?Political Correctness'.........defined
President of Club Polk -
Same issue here. Worked fine for a few months (straight from the packaging) then it just stopped. Several types of brand new replacement batteries and nothing.
It would be best to contact Polk's CS at: 1-800-377-7655 they can help.
