Replacing sl2500 with sl2000
I recently found some monitor 5 series II with the sl-2500 tweeter that are damaged. Is it ok to swap in a good sl-2000 tweeter in its place? Are the crossovers close enough to go back and fourth?
    F1nut Posts: 48,486
    Double no!
  • ratpin
    ratpin Posts: 29
    Hard to argue with your guys’ reasoning.
  • CH46E
    CH46E Posts: 3,398
    Yeah man, If both Pitt and F1 say no....
    Well thats a done deal for me.
  • westmassguy
    westmassguy Posts: 6,824
    The SL2000 has a relatively flat response, except for a resonance peak between 12-13KHz. The SL2500/3000 tweeters do not have that resonance peak, however their overall frequency response falls as the frequency increases. A contour network was installed on most of the models that received the new tweeters, to compensate for this. Since we don't have T/S parameters for any of the older Tweeters, there's no way to predict how they'll react. I would imagine they'd be overly bright with the contour network.
    Home Theater/2 Channel:
    Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
    Interconnect: Furez 10/2 with SpeakONs
    ICs: Custom Furez by Douglas Connections
    Den:
    Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
    Carver CT-3 Pre, Carver C-500
    dhsspeakerservice.com/
  • ratpin
    ratpin Posts: 29
    Thank you for your concise explanation. I’m more of a “why” than “what” guy.
  • skrol
    skrol Posts: 3,277
    edited December 2020
    I'm not sure where I got these, I have so much stuff.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Gardenstater
    Gardenstater Posts: 3,678
    That's from DarqueKnight thread The Tale of 5 Tweeters. He later amended that with the SL1000 data when he got ahold of a few of them. The RD0198 would be the replacement for that SL2500.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • skrol
    skrol Posts: 3,277
    Cool. Thanks for the update.
    It would be super to add the Peerless too and see how well they match the modern day replacements.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • I have found some data on the Peerless and I'll either post it in DarqueKnight's thread or somewhere else.
    George / NJ
    Crown D150 amp
    iFi nano iDSD DAC
    iPurifier3
  • DaveHo
    DaveHo Posts: 3,400
    Odd first post, but no spam link, so Welcome!
    F1nut Posts: 48,486
    He was banned years ago, total nut job.
    xschop Posts: 3,755
    You have to be a little nutty to return here.
  • TennMan
    TennMan Posts: 1,249
    That sl2000 should have been mounted up on the dash so it would be at ear level. Would get better SDA sound that way. :)
    xschop Posts: 3,755
    Or to drown out the busted exhaust, knocking rods, and squeaky brakes.
    pitdogg2 Posts: 22,756
    One of the things I really liked about the old vbullet platform is it had a page of alphabetical letters. you could go from A to z and look at all the names that ever signed up on this platform. I have not found a way to do that on the new vanilla platform
    And yes I remembered cornhole from back then..
  • Mystery
    Mystery Posts: 2,546
    SL1000 = 1.334
    SL2000 = 1.289
    Maybe these two are more swappable except for the 5db bump.
