Replacing sl2500 with sl2000
ratpin
I recently found some monitor 5 series II with the sl-2500 tweeter that are damaged. Is it ok to swap in a good sl-2000 tweeter in its place? Are the crossovers close enough to go back and fourth?
Double no!Political Correctness'.........defined
President of Club Polk -
Hard to argue with your guys’ reasoning.
Yeah man, If both Pitt and F1 say no....
Well thats a done deal for me. -
The SL2000 has a relatively flat response, except for a resonance peak between 12-13KHz. The SL2500/3000 tweeters do not have that resonance peak, however their overall frequency response falls as the frequency increases. A contour network was installed on most of the models that received the new tweeters, to compensate for this. Since we don't have T/S parameters for any of the older Tweeters, there's no way to predict how they'll react. I would imagine they'd be overly bright with the contour network.Home Theater/2 Channel:
Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
Interconnect: Furez 10/2 with SpeakONs
ICs: Custom Furez by Douglas Connections
Den:
Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
Carver CT-3 Pre, Carver C-500
dhsspeakerservice.com/ -
westmassguy wrote: »The SL2000 has a relatively flat response, except for a resonance peak between 12-13KHz. The SL2500/3000 tweeters do not have that resonance peak, however their overall frequency response falls as the frequency increases. A contour network was installed on most of the models that received the new tweeters, to compensate for this. Since we don't have T/S parameters for any of the older Tweeters, there's no way to predict how they'll react. I would imagine they'd be overly bright with the contour network.
Thank you for your concise explanation. I’m more of a “why” than “what” guy.
I'm not sure where I got these, I have so much stuff.
Stan
Main 2ch:
HT:
Other stuff:
You da man!
That's from DarqueKnight thread The Tale of 5 Tweeters. He later amended that with the SL1000 data when he got ahold of a few of them. The RD0198 would be the replacement for that SL2500.
George / NJ
Crown D150 amp
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Great info!
Cool. Thanks for the update.
It would be super to add the Peerless too and see how well they match the modern day replacements.Stan
Main 2ch:
HT:
Other stuff:
I have found some data on the Peerless and I'll either post it in DarqueKnight's thread or somewhere else.George / NJ
Crown D150 amp
iFi nano iDSD DAC
iPurifier3
And???
Odd first post, but no spam link, so Welcome!
He was banned years ago, total nut job.Political Correctness'.........defined
You have to be a little nutty to return here.Still modifying...
That sl2000 should have been mounted up on the dash so it would be at ear level. Would get better SDA sound that way.
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
Or to drown out the busted exhaust, knocking rods, and squeaky brakes.Still modifying...
One of the things I really liked about the old vbullet platform is it had a page of alphabetical letters. you could go from A to z and look at all the names that ever signed up on this platform. I have not found a way to do that on the new vanilla platform
And yes I remembered cornhole from back then.. -
Tubes Rule!!
SL1000 = 1.334
SL2000 = 1.289
Maybe these two are more swappable except for the 5db bump.
