Vintage Monitor and SDA Speaker Deals
1…198199201203204…259
  • engie490
    His ad says SRS and there are 13 screws on the crossover plate, so without a picture of the serial number and/or terminal cup, we have to believe him.
    Hopefully, those tweeters are 194s and all of the mids are correct. He states in the ad that all of the drivers were replaced 8 years ago.
    KEF Xq5s / Velodyne DD12 / Apollon Purifi 1ET6525SA / SST Thoebe II / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
    audioluvr Posts: 6,079
    They are SRS's the drivers say Polk on them so he probably means he replaced the tweeters
  • krazypolk
  • krazypolk
  • engie490
    My bad...there is one pic of a serial number. Using the magnifying tool in ebay, it looks like 5226 or 5228. So, assuming the other channel is around the same number, they should work with the Dreadnaught or AI-1. If the left channel is less than 5000, then not so much...
  • michaeljhsda2
    The type of interconnect socket is the determining factor of what they are.
    Blade/blade = Original SDA SRS (non-compatible with Dreadnaught or AI-1).
    Pin/Blade = SDS SRS 1.2 The speakers either have the RD0-194's or they been TL'd depending if the RD0-198 tweeters are installed along with the appropriate changes to the crossover) or they are SDA SRS 1.2TL with the RD0-198's. Dreadnaught or AI-1 compatible.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Gardenstater
    Gardenstater Posts: 4,936
    edited October 2020
    These early 5's with silver basket MW's and Peerless look pretty nice but typical NJ market prices $180
    https://www.ebay.com/itm/PAIR-Vintage-Polk-Audio-Monitor-5-Speakers-with-Peerless-Tweeters-Early-version-/133457735176?_trksid=p2385738.m4383.l4275.c10
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • spongebobsquarepants
    https://www.ebay.com/itm/303715170405
    Not really a deal, but they look like they're in great shape.
  • jdjohn
    jdjohn Posts: 3,443
    A pair of SDA-SRS in Nashville for $1,000...but missing a mid. They look to be in good condition otherwise.
    https://nashville.craigslist.org/ele/d/nashville-vintage-polk-audio-floor/7209400086.html
  • vmaxer
    vmaxer Posts: 5,124
    I just got home from Nashville a couple hours ago.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • michaeljhsda2
    michaeljhsda2 Posts: 2,216
    edited October 2020
    Those are 1.2's which can be converted to 1.2tl's. The binding post nuts need to be reversed, in order to hear them in correct phase. The diagram on the back is for the original SRS (blade/blade IC socket) and these are pin/blade.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • jdjohn
    jdjohn Posts: 3,443
    Yeah, wondering if these are worth the price given the need for a replacement mid, crossover upgrades, etc.
  • engie490
    engie490 Posts: 447
    I'd buy 'em! Can someone pick 'em up for me and deliver to Colorado? I'll definitely buy you some brews from some of the local breweries...
  • jdjohn
    jdjohn Posts: 3,443
    I could probably get his price down a bit because of the damaged woofer. Of course I'd want to check movement on the other mid-woofers, and check overall condition. Hmmm...
  • JayCee
    JayCee Posts: 1,509
    ➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S3.3 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • engie490
    engie490 Posts: 447
    jdjohn wrote: »
    Nice Work! It's down to $800!!!!!!!
  • Gardenstater
    How does a woofer cone get ripped off of the spider and surround?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • JayCee
    JayCee Posts: 1,509
    I might add...my PS Audio DirectStream DAC was open box and purchased from Music Direct. I was able to get another $500 discount by simply asking for a lower price. YMMV.
    JayCee wrote: »
  • engie490
    engie490 Posts: 447
    edited October 2020
    Telarc cannons!???!?!?
    Methinks the fact that it was one of the lowest ones is an important clue.
  • Gardenstater
    What might be the condition of the other ones if this ^^^ is the case? :#
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Mike Reeter
    Mike Reeter Posts: 4,315
    JayCee wrote: »
    JayCee wrote: »
    Yes, The people at M.D. will negotiate. Never hurts to ask.
    ^^^ Holy. And I don't mean like the pope.
  • engie490
    engie490 Posts: 447
    edited October 2020
  • engie490
    engie490 Posts: 447
    edited October 2020
  • engie490
    engie490 Posts: 447
  • engie490
    engie490 Posts: 447
  • engie490
    engie490 Posts: 447
  • engie490
    engie490 Posts: 447
