Music Fidelity M6si or Parasound HINT6
Well 8 months later I finally did it. I received my M6Si today. This is one hefty integrated, built like a tank. So far only a couple hours of listening and I am very impressed. Not going into details at this time but I am very happy.
Living Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
Office
Yamaha A-S501, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables -
Congrats!Political Correctness'.........defined
President of Club Polk -
Outstanding! Enjoy
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
'BOUT TIME!!!rburgess714 wrote: »Well 8 months later I finally did it. I received my M6Si today. This is one hefty integrated, built like a tank. So far only a couple hours of listening and I am very impressed. Not going into details at this time but I am very happy.I disabled signatures.
Yes, I was very slow to move on this purchase. It was definitely worth the wait. I think I am done.Living Room
Office
Glad you went MF."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Man I love this amp. Channel separation, huge sound stage, rhythmically spot on, detailed without being sterile, solid bass but not boomy, and just musical. It has so much power that I have barely got the volume to 10 o’clock. I could have probably got the M5Si for less coin and power but it’s nice to know it’s there. Almost a week in and I am just amazed.Living Room
Office
Damn, that sounds like a really impressive piece!
I was just checking out this Musical Fidelity integrated the other day. Their upper end stuff looks ridiculous: https://www.musicalfidelity.com/products/m8series/m8xi
M8xi - Specifications
Power Output (20Hz - 20kHz): 550 Watts per channel into 8 Ohms (870W into 4 Ohms); Peak 1.6kW into 2 Ohms
Maximum output voltage: 67 Volts RMS, 20Hz to 20 kHz; onset of clipping (190 Volts peak-to-peak)
THD+N: <0.004% typical, 20Hz to 20 kHz (XLR)
Signal/noise ratio: > 86dB ‚A‘-weighted (XLR)
Input impedance: 25KΩ (RCA), 50KΩ (XLR)
Frequency response: +0, –1dB, 10Hz to 100 kHz
Maximum peak output current: 105 Amps
Damping factor: 150
If measurements mean anything, those would be good ones.Gustard X26 Pro DAC
Damping factor: 150
That’s definitely another level or 3 up from mine, I can’t even imagine.Living Room
Office
Yeah I know! That's why it makes me curious about their higher end stuff, when you say how good the M6Si sounds. So cool!
Funny one of these just showed up on TMR:
https://tmraudio.com/components/integrated-amplifiers/musical-fidelity-m8xi-stereo-integrated-amplifier-m8-xi-silver-refurbished/2 Channel
Pre: Bryston BR20
Amp: Buckeye NCx500
Speakers: Polk L200
Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
Display: Sony XBR65Z9F
Pre: Anthem AVM90
Amps: Buckeye NC502
Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
Subwoofers: SVS SB16 x 4
Source: Oppo UDP-205, Apple TV, Amazon Fire
Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
Display: Sony XBR85Z9G -
Man , that MF M6s PRX amp sure looks sweet ....
230 watts into 8 ohms ( wonder what it does into 4 ohms )
Dual mono
140 amperes current .... ( wonder if that’s total or per channel - if per channel , WOW ! )
But , alas , NO 12v trigger .... WTF ??
About $2500 MSRP ... not too shabby ....
BkPS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO -
I was wondering the same as I haven't been able to find any info that it does 4 ohms. All the specs I see listed don't list 4 ohms.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream
I emailed them about that very question when the M6Si came out. They did state that it indeed was 4 ohm stable although I can't remember the power they stated...Remember, when you're running from something, you're running to something...-me
Thanks!Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream
