Music Fidelity M6si or Parasound HINT6
13»
  • rburgess714
    rburgess714 Posts: 618
    edited October 2020
    Well 8 months later I finally did it. I received my M6Si today. This is one hefty integrated, built like a tank. So far only a couple hours of listening and I am very impressed. Not going into details at this time but I am very happy.
    Living Room
    Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
    Office
    Yamaha A-S501, Auralic Aries Mini, LSiM 703s
    Douglas Connection ICs and Cables
    F1nut Posts: 51,964
    Congrats!
  • halo
    halo Posts: 5,618
    Outstanding! Enjoy :)
    msg Posts: 10,460
    'BOUT TIME!!!
  • msg wrote: »
    'BOUT TIME!!!
    Yes, I was very slow to move on this purchase. It was definitely worth the wait. I think I am done.
    Living Room
    Office
  • Glad you went MF.
    Harry / Marietta GA
  • Man I love this amp. Channel separation, huge sound stage, rhythmically spot on, detailed without being sterile, solid bass but not boomy, and just musical. It has so much power that I have barely got the volume to 10 o’clock. I could have probably got the M5Si for less coin and power but it’s nice to know it’s there. Almost a week in and I am just amazed.
    Living Room
    Office
    Clipdat Posts: 13,100
    Damn, that sounds like a really impressive piece!
    I was just checking out this Musical Fidelity integrated the other day. Their upper end stuff looks ridiculous: https://www.musicalfidelity.com/products/m8series/m8xi
    M8xi - Specifications
    Power Output (20Hz - 20kHz): 550 Watts per channel into 8 Ohms (870W into 4 Ohms); Peak 1.6kW into 2 Ohms
    Maximum output voltage: 67 Volts RMS, 20Hz to 20 kHz; onset of clipping (190 Volts peak-to-peak)
    THD+N: <0.004% typical, 20Hz to 20 kHz (XLR)
    Signal/noise ratio: > 86dB ‚A‘-weighted (XLR)
    Input impedance: 25KΩ (RCA), 50KΩ (XLR)
    Frequency response: +0, –1dB, 10Hz to 100 kHz
    Maximum peak output current: 105 Amps
    Damping factor: 150
    audioluvr Posts: 5,983
    If measurements mean anything, those would be good ones.
  • Clipdat wrote: »
    Damping factor: 150
    That’s definitely another level or 3 up from mine, I can’t even imagine.
    Living Room
    Office
    Yeah I know! That's why it makes me curious about their higher end stuff, when you say how good the M6Si sounds. So cool!
  • sgmsmg
    sgmsmg Posts: 556
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
  • gyosa
    gyosa Posts: 770
    Man , that MF M6s PRX amp sure looks sweet ....
    230 watts into 8 ohms ( wonder what it does into 4 ohms )
    Dual mono
    140 amperes current .... ( wonder if that’s total or per channel - if per channel , WOW ! )
    But , alas , NO 12v trigger .... WTF ??
    About $2500 MSRP ... not too shabby ....
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • Milito
    Milito Posts: 2,003
    I was wondering the same as I haven't been able to find any info that it does 4 ohms. All the specs I see listed don't list 4 ohms.
  • smglbrth
    smglbrth Posts: 1,498
    I emailed them about that very question when the M6Si came out. They did state that it indeed was 4 ohm stable although I can't remember the power they stated...
  • Milito
    Milito Posts: 2,003
    Thanks!
