Monitor 7 with TL Upgrade
westmassguy
Clarity CSAs, Mills MRA12 Resistors, Hand Tuned Salvaged Bobbin Inductors, New Imported Insulating Binding Posts:
Home Theater/2 Channel:
dhsspeakerservice.com/
Sweet!
Purdy
Thanks for sharing. Did this go from a SL2000 to a RD098?
George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Nice. It's like the caps take up the same volume as the terminal plate/pcb boards.Don't take experimental gene therapies from known eugenicists.
Gardenstater wrote: »Thanks for sharing. Did this go from a SL2000 to a RD098?
CorrectHome Theater/2 Channel:
dhsspeakerservice.com/ -
You have to get creative with the limited real estate.Home Theater/2 Channel:
You saved that customer something like $70 over using Sonicaps, I think.
George / NJ
iFi nano iDSD DAC
iPurifier3
Dave have you ever attempted a Peerless to RD0198 mod, or would you advise the customer against that?George / NJ
iFi nano iDSD DAC
iPurifier3
Gardenstater wrote: »Dave have you ever attempted a Peerless to RD0198 mod, or would you advise the customer against that?
So, just to reassure me, even a Peerless tweeter that has been played for 40 years is still most likely just as good sounding (with appropriate XO) as a newly manufactured RD0198? In other words they don't really wear out like a MW does?George / NJ
iFi nano iDSD DAC
iPurifier3
Gardenstater wrote: »So, just to reassure me, even a Peerless tweeter that has been played for 40 years is still most likely just as good sounding (with appropriate XO) as a newly manufactured RD0198? In other words they don't really wear out like a MW does?
I've rebuilt dozens of Peerless Crossovers for happy customers. Let your own ears decide.Home Theater/2 Channel:
I have myself as a happy customer on my 7B crossover rebuild (with Danish Peerless) but unfortunately I have no way to compare. I guess I'd have to get a 7C and do the mod you did and then A/B the two pairs of speakers.Post edited by Gardenstater onGeorge / NJ
iFi nano iDSD DAC
iPurifier3
What has to be altered in the crossover to go with the RD-0198?
Same as the Monitor 5 SL3000 Modification:
5.8uf shunt capacitor across the 2 ohm resistor, and replace the .23mH inductor with a .27mH @ .5 ohms
Change the .110 quick connect on the tweeter negative lead to .205
So the only difference between a 5B and 7B is the cabinet volume and passive?Don't take experimental gene therapies from known eugenicists.
Well not exactly. That XO above is the similar to my 7B's with Danish Peerless and MW6500s, except I have a 1A fast blow fuse instead of the polyswitch and the tweeter resistor is 4.5 Ohms and there is also a 2.7 Ohm resistor in series with the .23mH inductor and in parallel with the tweeter. Close to this except 4.5 Ohm instead of 4.7 Ohm. The fuse only has 190mOhm resistance as opposed to 500mOhm (?) for the polyswitch.
I believe the 5B and 7C XO'ers may be the same because they both had the SL2000 and MW6502?
iFi nano iDSD DAC
iPurifier3
Correct. The larger cabinet and tuned passive give the 7 deeper bass, but everything else is essentially the same.Home Theater/2 Channel:
Gardenstater wrote: »So the only difference between a 5B and 7B is the cabinet volume and passive?
Your 7 is a different generation/revision. The 5 from that generation (time period) also had the 8 ohm MW6500, and Peerless. Different animals.Home Theater/2 Channel:
Yes I edited my post to say that I believe 5B and 7C were comparable XO'ers, apparently. I get that the PR's were different sizes and tunings. I am ASSuming that the Model 5 and 7A and 7B had identical or nearly identical XO'ers as long as they had the Peerless and MW6500, which are 8 Ohms. The 5B and 7C have the SL2000 and MW6502, which is 6 Ohms.
Correction: MW6502 is 4 Ohms.George / NJ
iFi nano iDSD DAC
iPurifier3
The MW6502 is 4 ohm.Home Theater/2 Channel:
Thanks. I corrected it. I guess I was remembering that the 7C with the SL2000 and MW6502 was 6 Ohms. SL2000 appears to be around 8 Ohms avg. impedance.
https://us.v-cdn.net/5021930/uploads/editor/0r/k60tgrjai18r.jpg
Thiele Small Parameters of misc. MW's:
https://forum.polkaudio.com/discussion/133992/thiele-small-parameters-for-mw6500-driversGeorge / NJ
iFi nano iDSD DAC
iPurifier3
Last question, is the Passive radiator found in 7B the same as CRS+?Don't take experimental gene therapies from known eugenicists.
No idea. There were two different passives used for the CRS/CRS+ depending on the generation. The 2nd generation used the SW102, the 3rd generation used an SW100, and the 4th generation used the SW102.Home Theater/2 Channel:
Hey! Those are mine! I finished assembling them last night and now in the burn-in process. They sound great to far. Thanks for the top notch work David! I'll get back on this thread once I've hit 100-200 hrs.
todmarsden wrote: »Hey! Those are mine! I finished assembling them last night and now in the burn-in process. They sound great to far. Thanks for the top notch work David! I'll get back on this thread once I've hit 100-200 hrs.
My pleasureHome Theater/2 Channel:
I have a pair of 5B that I'd like to do the SL3000 conversion.
In the schematics, I see the 5B original, 5B Rev with SL2000 and the 5B SL3000 (though the schematic says SL-2000. Those are shown in the previous posts. The one lacking is the Monitor 5 Series 2 (last version used SL2500). I'm wondering how the 5 series 2 differs from the others. One difference would be the elimination of the polyswitch. It is likely similar to the Monitor 7 series 2.Stan
Main 2ch:
HT:
Other stuff:
