Linear power supplies
Does anyone have experience using a an upgraded linear power supply? Just curious if you've had positive improvements by using a linear power supply versus a switch mode/wall wart.
I am considering a product that offers an upgraded linear power supply. Here are the specs of the upgraded power supply:
"Mains Input:115VAC 60Hz
DC Output Voltage - 15V, 18V, 21V DC
Output Current - 1A Continuous, 2A Peak
Output Noise <-85dBu
Fuses
Main Input - T800mA Slow Blow
Internal - F2.5A Fast Blow
Overvoltage Protection
>24V DC
Output current is rated at 1amp continuous, but the supply can deliver more than double this for short periods. With a compact toroidal transformer and high-quality capacitors used throughout, long life and continued high performance are ensured."
  • brgman
    brgman Posts: 2,859
    Have you looked to see if SBooster offers what you need?
    I’M OFFENDED!!!!
    Clipdat Posts: 13,100
    It looks like they do. Theirs is $360, this one I'm considering is $337.
  • machone
    machone Posts: 1,573
    Mojo-Audio.com
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • DaveHo
    DaveHo Posts: 3,583
    I use s welborne PS with an SMSL M8 DAC. Very obvious improvement over the supplied PS.
  • jdjohn
    jdjohn Posts: 3,415
    Might it depend on the device being powered, and how being used? For example, I remember reading somewhere regarding streamers/players with no internal DAC, a LPS wouldn't make a difference since it is digital-in and digital-out. But for analog-out (built-in DAC), the power supply could make a difference.
    mhardy6647 Posts: 35,373
    I don't know why youse guyses don't go more for laboratory power supplies? Superb quality and inexpensive on the 'aftermarket'.
    e.g., I bought this HP for playin' with chip-amp and Class D type thingies.
    33943321368_709a00d16b_b.jpgDSC_4595 (2) by Mark Hardy, on Flickr
  • brgman
    brgman Posts: 2,859
    I thought Welborne went the way of the Dodo bird but maybe not.I used one of those years ago with a squeezebox and it worked well.Just took forever to get after ordering.I know some folks have not so nice things to say about them.
    I’M OFFENDED!!!!
  • jdjohn
    jdjohn Posts: 3,415
    brgman wrote: »
    On the SBT, were you using it with analog-out, digital-out, both? Curious as to where it made a difference.
  • IIRC @DarqueKnight had good luck with TeraDak linear PSUs.
    I’m thinking about one for my Raspberry Pi...
    https://www.ebay.com/itm/222531578345
  • afterburnt
    afterburnt Posts: 7,892
    edited September 2020
    I have one on one of my Auralic Minis I don't think I ever hooked it up with the stock wall wart however I have another Mini in another system that I ran with the standard wall wart that I upgraded to an ifi ipower wall wart which was an improvement over stock but I also swiched the DAC wall wart to an ifi at the same time. Both cost a lot less than one linear power supply. For fifty bucks maybe you want to try that fist?
  • afterburnt wrote: »
    That TeraDak is only 66 bucks, so not a lot more lol....... not saying its BETTER than the iFi....
    There is also this one which has multiple outputs....
    https://www.ebay.com/itm/DC-15W-DC5V-2-5A-TALEMA-25VA-Dual-USB-Low-Noise-Linear-Regulated-Power-Supply/273360652983
    I eschew SMPS (switchmode power supplies) -- shhh, don't tell ASR! ;)
    The high-frequency hash they generate (which has to be dealt with both within and outside of the P/S) is the price one pays for their high electrical efficiency.
  • afterburnt
    @mhardy6647 the linear that I have runs hot as hell, is that any indication of efficiency?
    afterburnt wrote: »
    Yup.
    The SMPS run cool -- they're very green.
  • DaveHo
    DaveHo Posts: 3,583
    brgman wrote: »
    Hey, Mike! Nice to see you chime in. Got my welborne used from a member here. Yep, the company is long gone and didn't go out on a high note.
    jdjohn wrote: »
    Hey Jody. It's for a tube preamp in DJ mixer form: https://mastersounds.co.uk/collections/mixers/products/radius-two-valve
    Here's the PSU: https://mastersounds.co.uk/collections/mixers/products/linearpower
    afterburnt wrote: »
    Just checked and the iFi unit doesn't output high enough. Thanks for the heads up though, that looks like a cool product.
  • jdjohn
    jdjohn Posts: 3,415
    Clipdat wrote: »
    Interesting pro product there. I still maintain my amateur status :)
    Looks to be all analog, so might benefit from a LPSU.
  • Too bad. I have had great results with the iFi iPower myself. I am using it with the iDefender which allows the iFi to supply my DAC with power instead of the computer (and now my Squeezebox Touch I just bought). It uses military grade Active Noise Cancellation. I don't think it would be of any advantage to upgrade the power supply to the SBT since it is just a digital output situation to the DAC but who knows? I'd like to try it if I had another iPower.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    jdjohn wrote: »
    I've wanted it for like a year now. Such a cool product.
  • jdjohn
    jdjohn Posts: 3,415
    Clipdat wrote: »
    jdjohn wrote: »
    How do you plan to use it? In what type of application/situation?
    Just for fun at home with my DJ setup. Got some different equipment hooked up right now, but this is it:
  • jdjohn
    jdjohn Posts: 3,415
    I don't see a microphone...yet B)
    Yeah, no mic either.
  • afterburnt
    Clipdat wrote: »
    Some DJ you are lol
    I'm not the same kind of DJ as @erniejade
  • @Clipdat, here is a thread from the "Steve Hoffman" forum (2018) regarding the new Musical Surroundings Linear Power Supply. I have a Phonomena II+ and was searching about a month ago if a Linear Power Supply makes a difference. I was especially interested for info regarding the Musical Surroundings Linear Power Supply because it is so expensive at $650.
    One of the "verdicts" in the thread and substantiated by others was the Musical Surroundings Linear Power Supply at $650 "turns the $700 phono preamp into an AMAZING $1400 phono preamp". I have not purchased one yet so believe the thread at your own ri$k.
    I think this verdict satisfies @jdjohns statement: "But for analog-out (built-in DAC), the power supply could make a difference".
    If you read the thread, you will find our own F1nut has a couple of posts in the thread.
    Also, the thread contains a link to this blog: Power Supply Design: Switch-Mode vs. Linear | Simply Smarter Circuitry Blog.
    Anyone tried the new Musical Surroundings Linear Power Supply?
    https://forums.stevehoffman.tv/threads/anyone-tried-the-new-musical-surroundings-linear-power-supply.785876/
    For completeness, here is another supplier of Linear Power Supplies.
    I have a friend who has purchased from this supplier many times.
    http://www.swagmanlab.com/
    Harry / Marietta GA
