WTB: MW 5602 Driver
CraigLaing
Hi all. I have a set of Polk Audio Monitor Series 10 Speakers and one of the woofers has gone. Luckily I have a set of 7's and 5's so was able to swap one over. Anyone within Australia have one they'd part with? Happy to purchase from US if that's my only option.
Thank you
Thank you
Details of woofer; Assembled in Mexico April 14, 1989.
Never heard of a mw5602, do you mean 6502? I'm thinking your monitor may need mw6503.
Ahh yes, lol. It’s a 6502.
Still I see on all the schematics the early model 10 used MW6500 and the later models all used MW6503. I feel the MW6502 is not the correct driver. It IS the correct driver for monitor 5 & 7
The 6502 is 4 ohms nominal. The 10s take two 8 ohm woofers in parallel.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Ahh ok. Thanks guys.
Well I need a WM6500 then. I just assumed they were all the same and swapped the offending woofer from the one in my 7's. Good thing I haven't used them.
