WTB: MW 5602 Driver
Hi all. I have a set of Polk Audio Monitor Series 10 Speakers and one of the woofers has gone. Luckily I have a set of 7's and 5's so was able to swap one over. Anyone within Australia have one they'd part with? Happy to purchase from US if that's my only option.
Thank you
Thank you
Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
Interconnect: Furez 10/2 with SpeakONs
ICs: Custom Furez by Douglas Connections
Den:
Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
Carver CT-3 Pre, Carver C-500
dhsspeakerservice.com/
Exclusive Distributor of Gimpod's Custom SDA Circuit Boards
Well I need a WM6500 then. I just assumed they were all the same and swapped the offending woofer from the one in my 7's. Good thing I haven't used them.
