Rings,Don't have to be Larry's,similar would be nice.
Putting the feelers out here ...To suit 1.2's <3
«1345
    Toolfan66 Posts: 18,165
    I wish I had it in me to commit doing another run but my house keeps me busy, and I like my free time as well.. B)
    nooshinjohn Posts: 25,990
    Toolfan66 wrote: »
    You have done so much for everyone on this forum, my friend. We all owe you a debt of thanks.
    F1nut Posts: 51,962
    Two words, hurricane nuts.
  • invalid
    invalid Posts: 1,519
    If you can't get Larry's rings, hurricane nuts are the next best thing.
  • ptrooper
    ptrooper Posts: 501
    Sda Srs. already have inserts. I have Used hurricane nuts before and won’t again.
    I’ll have to wait 🤔nothing compares to Larry’s. Rings. ❤️
  • ptrooper
    ptrooper Posts: 501
    Toolfan66 wrote: »
    Let me help towards your costs of renovations Larry 😀 Don’t worry about doing a big run!
    I am seriously contemplating shipping a set of 1.2’s to Australia .
    Cheers
  • invalid
    ptrooper wrote: »
    Now I really want a pair of Larry's rings if they are that much better than hurricane nuts.
    F1nut Posts: 51,962
    I've used hurricane nuts and Larry's rings, they accomplish the same thing.
  • ptrooper
    ptrooper Posts: 501
    sound different though!
    txcoastal1 Posts: 13,519
    Nuts and rings....yep definitely different :p
    F1nut Posts: 51,962
    ptrooper wrote: »
    That is in your head.
    Viking64 Posts: 7,617
    Hurricane Nuts: When you stand naked on a beach facing an approaching tropical storm and the wind blows your sack back into your butt crack.
  • ptrooper
    ptrooper Posts: 501
    edited August 2020
    My .05 % hearing loss tells me different.
    Lets not get of track now.
    If any one has them hidden away, unused or the know how with the tools and equipment to make them, by all means pm me!
    Post edited by ptrooper on
  • Gardenstater
    Gardenstater Posts: 4,802
    If you have old speakers that are goners that you are not going to try to fix you could cut away the steel rims and could mount them inside your cabinet with a hurricane nut at each hole and some JB Weld. Bingo. Larry's Rings. Don't have a clue how to get the one for the passive radiator in however without bending it, which would definitely entail grinding away some of the flange material to make that possible.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • ptrooper
    ptrooper Posts: 501
    edited September 2020
    @Toolfan66,I hope you don't mind if anyone copy's your rings to a certain degree B) I'm currently imagining other version of Larry's rings <3
    Over time i know you had to cut certain sections down to accomodate internal bracings to some models, SDA SRS etc.
    If there is any other info you'd like to share from your knowledge base ,that would be nice!
    Cheers again for everything you have done for everyone including myself etc.Theres a piece,you have touched in all the polks i have !
  • Gardenstater
    Unless you have access to a waterjet or laser cutting machine, I wouldn't think they would be very easy to make and definitely wasteful of sheet metal either way. I don't think they could be bent up out of flat stock and welded, but with the right machinery may even be possible. Other option is to machine them from huge cylindrical steel stock, a la xschop.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Yes,A thicker base would be a nice upgrade to Larry's rings ,i found glueing them in was better than letting them sit there. When testing my two identical sets of SDA SRS with firm hard knocking they were ringing or should i say resonating extremely differently from each other.
    Note: i drilled once without any forward and back reeming with the drill bit ,i then firmly pressed them into place so any slightly angled holes would have slight difference in tensions between each hole!
    Having high concerns over the "huge" difference in sound between the two SRS when knocking ,i even had friends who listened whilst i tapped and knocked , they could hear the difference from well over 20 feet away.
    Glued = no difference between my two sets.
    My SDA SRS sound much better with them glued!...nothing fancy ,I just wiped a generous amount of power grab along the outer edge of the allready installed rings! easy peasy!
    I dare people to try it!
  • I have never used Larrys Rings but I have said here before that if the steel is thin which it appears to be, that they should be epoxied to the particle board. So I feel what you are saying backs that up or confirms that.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Not forgetting ,Larry's rings are a huge game changer even if not glued in!
    I beleive , no matter what rings go into the old Polks, taking the time and epoxying them in completely, will definitely give further gains again.
    Hopefully i'll be testing that theory in the near future.
    xschop Posts: 5,369
    I replied in private on my design but also believe gluing in the thinner rings also increases rigidity of the old particle board.
    I don't own 1.2TLs so a good design can be achieved by looking at the factory inner bracing and go from there.
    Post edited by xschop on
  • ptrooper
    ptrooper Posts: 501
    I only have the SRS but from stalking pictorial memory, the 1.2TLs have much less bracing due to a more ridged bezel which i think was from laminating so a much less chance of bracings being in the way!
    pitdogg2 Posts: 27,249
    SRS are made from particle board, and yes much more bracing. 1.2 is medium density fiberboard or MDF. They may only have the long center brace inside down the middle between the drivers
    Much more rigid.
    At least that is what I was led to believe.
    xschop Posts: 5,369
    So a thicker, semi-circular (top-bottom) rings would clear the internal bracing? The bracing between MWs on 2B's is the reason why I passed making a full-circular set. A thicker semi-circular set would clear the center bracing and make the baffle much more rigid to boot.
  • ptrooper
    ptrooper Posts: 501
    My two sets of SRS and 2.3'S front bezels were made from a fibre board but their sides and rear panels were definitely a partical board.
    MY crs+, 1b's and 2a's front bezels were definitely a partical board! ..With this partical board ,you had to take care when working near the edges as they could quite easily crumble when drilling etc !
    Much more rigid.
  • I think whatever material is used we want the highest stiffness to volume ratio (that's not what she said :D ) For that reason I don't really think carbon fiber would be good even though it is stiffer than steel pound for pound (I believe...have to check this). Titanium may be cost prohibitive. It would be interesting to check if any aluminum alloys would be better than steel, given the right temper. I doubt it.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    You guys are WAY WAY over thinking this.
    xschop Posts: 5,369
    7505-T6 or 4140 cold-rolled. Both will do the job, The 7505 will not oxidize. The 4140 steel can easily be primed/painted before install.
  • Gardenstater
    Stainless Steel would probably be too expensive. Usually with things like this cost effectiveness and ease of manufacture win out. If it is going to continue to be a sheet metal fabrication product I think PEM nuts are the way to go, pressed into the sheet metal.
    Post edited by Gardenstater on
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,369
    How so?
  • Dr_Wu
    Dr_Wu Posts: 356
    I have a set that Larry anodized. Sharp looking!
