Infinity RSII....??? Any one had ears on them?
11112141617
    Tony M Posts: 11,566
    :o:p
    audioluvr Posts: 5,866
    Remember when the villagers stormed Dr. Frankenstein's castle with torches and pitch forks? Intervention isn't what it used to be...
  • BlueFox
    BlueFox Posts: 15,251
    Looks like the body is missing, at least for the top speakers.
  • CH46E
    CH46E Posts: 3,595
    BlueFox wrote: »
    What do you mean by body?
  • CH46E
    CH46E Posts: 3,595
    edited July 2020
    They look to be in fantastic condition. Nice rich color in the wood. Drivers all look right.
    Maybe the foam in the rear of the mids is missing or so it appears by the way the light shines through the cones. That's an easy fix though.
    I'm also guessing they dont have the original grills.
    How much they asking?
  • BlueFox
    CH46E wrote: »
    BlueFox wrote: »
    I was joking.
  • CH46E
    CH46E Posts: 3,595
    BlueFox wrote: »
    CH46E wrote: »
    BlueFox wrote: »
    I was joking.
  • CH46E
    CH46E Posts: 3,595
    Even at $400 that's a smoking deal.
  • CH46E
    CH46E Posts: 3,595
    edited July 2020
    You are 100% right. I've been buying parts here and there. I added up my totals so far on caps, resistors, binding posts, wire, ptfe tubing, solder and I was shocked.
    $1,435.00 so far. That's pretty much everything I need to do the crossovers as I'm not planning on changing the inductors.
    That does not include the cost of the speakers themselves.
    So...I now know what you mean!
    I would not call this an investment though. I love the way they sound and only hope they sound a LOT better when done. I'll be removing them from my system soon and pulling all the drivers so I can work on the cabinets a little. I may do some sanding and stain or I may wrap them in some birds eye maple I have.
  • CH46E
    CH46E Posts: 3,595
    la2vegas wrote: »
    CH46E wrote: »
    Ok, on that note I think I'll pass on them.
    Dont let that scare you. I could have done it far far cheaper. I just wanted to use premium parts.
  • CH46E
    CH46E Posts: 3,595
    la2vegas wrote: »
    CH46E wrote: »
    Also, if you do get them I can send you all my old caps. Some people have tested thier large can caps in them and found many if not all still within spec. Some are large high quality caps. I dont have anyway to test caps. They sounded pretty darn good with them. I just cantnleave anything alone. I have to modify everything. Sickness? Maybe.
    CH46E wrote: »
    The way I see it. You are clearly not a "flipper". When you are done, you will have a speaker that will perform as well as any new speaker in the five figure range. Not to mention the "COOL" factor of a fully restored and modded vintage item.
    R
  • CH46E
    CH46E Posts: 3,595
    Quick question guys. I did not want to start a new thread just for it.
    Looking for a entry level turntable in the under $400 budget. I just dont know much.
    Direct drive or belt drive turntable???
    Moving magnet??? Thanks
    Clipdat Posts: 13,078
    Used Technics SL-1200mk2 that hasn't been used to DJ with off your local craigslist.
    I also like auto return models. So much nicer to be relaxed and let the TT arm return and then the TT shut off by itself.
  • BlueFox
    Tony M wrote: »
    LOL. More than once I woke up with the needle at the end and going kabonk, kabonk, kabonk.
  • CH46E
    CH46E Posts: 3,595
    edited July 2020
    If I can't find a Technics SL-1200mk2, (prices are all over the place)
    Should I go for direct drive or belt drive? Or is that that much important?
    The advice I was given when I asked the same thing was "Don't look into that rabbit hole!"
  • CH46E
    CH46E Posts: 3,595
    On another note I found a local wood working shop that I'm going to speak with about helping with the crossover boxes. I think I'm going to use these RS 1b shells for a stand alone crossover. Maybe a small short tower that sits next to the RSII, on the inside between the speakers. It would be a part of the RS 1B shells so the grain and geometry would match.
    BlueFox wrote: »
    Tony M wrote: »
    Me too. :D
    nooshinjohn Posts: 25,877
    CH46E wrote: »
    When you are ready for an end game table, let me know...
  • CH46E
    CH46E Posts: 3,595
    Got some more caps in today. Miflex copper oil cap. Very heavy. And the largest 1uf cap I've ever seen. Appear to be very well built. They matched them down to a thousandth. a189ocv0ga5e.jpg
  • invalid
    invalid Posts: 1,441
    How pricey are those?
  • CH46E
    CH46E Posts: 3,595
    43.00 British pounds sterling each for the 1uf, and 14.00 each for the .12uf.
    I buy from HiFi Collective so it's always British pounds. Conversion to $ changes daily.
    These were a lot cheaper than the Jupiter caps I was going to get. But some reviews state these are as good as the Jupiter caps.
  • CH46E
    CH46E Posts: 3,595
    edited July 2020
    CH46E wrote: »
    I'm almost afraid to ask what that would cost buddy!
    CH46E wrote: »
    Be afraid. Be very very afraid!
  • invalid
    CH46E wrote: »
    They look like really nice caps
  • Gardenstater
    Gardenstater Posts: 4,726
    edited July 2020
    Very cool caps. Polish too. I wonder what the purity of the Cu foil is. I see they only go up to 15uF. A 12uF cap for the high pass side of my 7B crossovers would *only* have cost me $359 x 2 lol. 3-3/8" dia. x 5" long wouldn't have fit on the Polk PCB (to say the least).
    Great rating of 13+ on humblehomeadehifi.com site.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
