PSW505 light on rear not switching from red to green
Answers
I have sent you a PM
Hi All, I'm having a similar issue on my PSW505 amp. I get constant crackling and popping while its plugged in. It's 3 years old but gets very little use- it's in a basement rec room that we watch movies in a few times a month. It's probably out of warranty, I'm sure. Is there a source for the amplifier boards? Seems like a horrible waste to pitch a sub that has $3 worth of failed capacitors on it.
Hello,
The bass amps come with a three year warranty, try and find the exact date of purchase. Polk sells replacement amps for $150.00, but as a member of Club Polk you get a discount. I believe they are currently out of stock, but believe they'll have them in three weeks. For information call them at: 1-800-377-7655. -
Hi, My Psw505 has the same problem, the light does not go from red to green, Any one here has a schematic of the board they dont mind sharing.
KennethSwauger wrote: »Hello,
Let me try and get the amplifier's schematic and I'll send it to you.
Regards, Ken
Is it possible to still get a schematic? Support keeps telling me that it is only accessible by technicians but looking at this thread... a few people have it. -
My PSW505 is doing the same, red light (sometimes) and buzzing with heartbeat but no output. I purchased from Amazon Jan 2016 so it's out of warranty. I bought it for $169 so I think a $150 repair is out of the question. Can you send me a copy of the schematic? Thanks.
Hey all,
I have two PSW505 subs and I had this occur on both amps. Both were replaced and now the replacement I got in July has now crapped the bed and Polk will not replace the replacement since it is out of warranty. Service number from July is 200612-001275. Any help from a Polk manager would be greatly appreciated. I’m getting a little disenfranchised with having this persistent issue.
Thanks,
Matt -
Hi,
My Psw505 has the same problem, the light does not go from red to green, Any one here has a schematic of the board they don't mind sharing. -
Had same issue as well for my PSW505 sub. It is within warranty at the moment. I don't mind fixing myself if possible, but can ship back to Polk
Greetings! Another PSW505 that won't come out of standby mode here. I wish I had handled this before it went out of warranty. I'd appreciate anyone that could kindly send me the schematics. Thanks in advance!
I'll email it to you.
Thank you very much!
Glad to help, take care!
I also have one that just went out. Light stuck red after not being plugged in for a few months. Any help appreciated!!
The best place to begin would be to contact Polk's CS at: 1-800-377-7655 you should have the date of purchase available when you call.
I have the same problem I bought this under three years ago. Looks like the amp is under warranty for three years. Sent an email to customer service with proof of purchase since there is no support in the weekend. Hopefully this can get resolved quickly.
So I'm adding myself to the list of the PSW505 that won't come out of standby mode here with the red light on constantly. Unfortunately, it's out of warranty. I'd really appreciate it if anyone that could kindly send me the schematics.
Send an email request to: Kim.Jasper@soundunited.com
Don't believe a word I say, but this is what worked for me, friends:
[Same symptoms as posted above, crackling etc...]
While playing music, Receiver Sub Output = Yes, PSW505 On>>Unplugging and re-plugging LFE Cable switched light from Red to Green. High volume levels corresponded directly with frequency of Red flashes in solid Green light. Volume knob position at 40-50% yielded transparent interior base.
Cycle Standby/Auto/On. A few hard taps might work too
most of all, believe it's gonna go back to Green.
I have a polk psw505 and I have no red or green light and sun crackles like a scratching noise and bass cuts in and out like the amp is bad
SeleniumFalcon wrote: »Send an email request to: Kim.Jasper@soundunited.com
Hi, I have an issue with my PSW505 as well. In my case no red light even. I've checked it has +-15volt but doesn't have +-57 Volt. Can you please send me schematic? I really appreciate. -
any idea how long this amp replacement last?
Any Idea how long this replacement amp will last?
How long will it take you to install all of the screws? Carp, did I use my out loud voice?
